Gas leak stained my frame!!! Solutions????
So I had bought my bike from ebay (Don't do it unless you get it checked out first) and it started leaking gas from two tube seals on the left of the tank where the vent from the gas tank is. The seals were cracked and a verrrrry slow drip started. Well it picked up a little bit of grease and grime on the way down my fairing and landed on my powder coated frame and continued to run down until it hit the ground. Needless to say, there is a small puddle under my bike now after a week. I finally got the parts I ordered from triumph (which took 2 weeks and 95 cents each) to fix it. The leak is stopped now but I go to clean the bike and the frame is still dirty. The D@MN Powder coat is like it's stained. Anyone else run into this problem and found a solution you can use to clean it off without ruining the powder coat? I have a two foot brown stain on my silver powder coat going from my tank running down to my foot rest to the ground. Pisses me totally off after I just got a new paint job (Which I will be posting pictures of shortly!)
