Assembling the DSSA???? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!SportbikeTrackGearNew Bonneville
Old 04-06-2008, 09:40 PM   #1 (permalink)
Favourite Bike: 04 Daytona 955-GSXR Forks
RJScotti's Avatar
Other Motorcycle: 01 Sprint ST
Extra Motorcycle: Daytona 1050 Frankenbike
I'm mounting a Double Sided arm to my frankenbike frame with what looks like all the correct hardware (according to the manual). Strange. It seems that there is a space required but none in my parts pile. The left side has a block spacer (rides on the inside of the needle bearing) that is basically flush with the left side of the swingarm when assembled.
Putting it all together it seems like there should be a space of say.. 1/2" thick between the left frame and the end of the block spacer. The BikeBandit parts diagram does not show or list a spacer at this location.
Anybody have of these apart that can vouch for a spacer....or no spacer?
RJScotti
09 Bonnie SE
04 Daytona 955i - Black "Union Jack"
02 Daytona 1050 "Frankenbike"
RJScotti is offline   Reply With Quote
Old 04-07-2008, 04:26 AM   #2 (permalink)
Favourite Bike: '99 Daytona 1200 SE
tritonwow's Avatar
Other Motorcycle: '95 Super IV
Extra Motorcycle: '67 eNorton project
I have a "black project" I'm working on. Look at the main frame and fittings schematic, 2: SPACER RING,34.5X17.5X9, DOUBLE SIDED SWINGARM
This is a swag because my project is in the mainland with my brother. He told me the DSSA didn't line up; needed about an 1"-1.5" on the left spacer. I found that spacer ring in the schematic and then was lucky to ID one in a pile of bolts on Fleabay. My brother said that did the trick. Now I'm looking for shock linkage.
Let us know how it works out.
T
http://www.triumphrat.net/memberalbu.../15516/cat/500
I am a volunteer, knowing well the hazards of my profession.
tritonwow is offline   Reply With Quote
Old 04-07-2008, 08:19 AM   #3 (permalink)
RJScotti's Avatar
Thanks
Triton
Thanks for that info. The BikeBAndit parts schematic doesnt show that part but my manual refers to one. I'm just wondering how to read thopse dimes. Maybe I can make the part.
Is 9mm the thickness or is 34.5mm? I'll assume the 17.5 is the inside diameter (hole). Do you recall if your spacer was about 34mm thick?
RJScotti
09 Bonnie SE
Old 04-08-2008, 03:04 AM   #4 (permalink)
tritonwow's Avatar
The bike bandit schematic; That's where I first saw it.
iconhttp://www.bikebandit.com/houseofmot...m6891sch513215
Anyhow, I'll have to call my brother to get the dimensions but looking at the pic I'd say 34.5 OD, 17x ID, and 9mm thick. I'll ask him to take an actual picture of it too.
Old 04-08-2008, 10:34 AM   #5 (permalink)
RJScotti's Avatar
I made a spacer from some machine bushings, installed it yesterday and it worked perfectly. Thanks so much for your help.
RJScotti
09 Bonnie SE
old discussion: SSSA vs DSSA luiz Daytona Deliberations 6 07-23-2007 12:27 AM
Adjusting the chain with the DSSA? triumphdude184 Daytona Deliberations 7 03-15-2007 03:53 PM
sssa vs. dssa bete Daytona Deliberations 1 09-06-2006 07:51 AM
SSSA? DSSA? HUH? SaddleTramp Sprint Forum 6 09-08-2005 07:46 AM
'02 DSSA Daytona hugger on an '00 RS?? Milo Sprint Forum 0 06-03-2005 08:16 PM
