Engine light - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew Bonneville
Old 04-06-2008, 11:06 AM   #1 (permalink)
Engine light
The check engine light came on this morning, is there a way to check this without a scan tool? Ambient temperature at time of starting was 50 F. Battery was a little low but bike started in less than five seconds and sounded ok. Oil level was checked and is ok.
NotADuc is offline   Reply With Quote
Old 04-06-2008, 12:41 PM   #2 (permalink)
DEcosse's Avatar
There is no way to get the code that set it w/o a scanner.
The low battery may well have been the cause in this case.
If it is not a prolonged condition the MIL light will usually reset after three warm-up cycles. The code will remain for 40 cycles so you can still have it pulled later. If the fault condition remains however the light will stay illuminated.
T'Rat.net BOTM November 2009
Old 04-06-2008, 03:28 PM   #3 (permalink)
Thanks for the info. I will start it a couple of times over the next day or two and let it warm up to normal temp range and see if the light goes out.
Engine Light "ON" Mossy21 Speed Triple Forum 6 11-17-2006 01:50 PM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Engine Light just came on. amraam Speed Triple Forum 2 05-10-2006 10:27 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
Fuel light/Engine light zore Maintenance & Workshop Talk 1 06-28-2004 12:52 PM
