Engine Running Weird... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-02-2008, 06:35 PM   #1 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
My bike has been sitting at home for a few weeks (on the battery tender) and I decided to commute it to work today. On the way in, it seemed fine. No problems to speak of...
I went home for lunch to check on my dog that just had an operation a few days ago and I stopped to grab some lunch. When I was leaving the restaurant, it didn't want to start. I finally got it to kick over but then, on my way back in to the office, it started to sputter and miss on 1 cylinder.
It's weird, it comes and goes. Sometimes it will idle fine, then it will get rough, I'll stab the throttle a little and it will be smooth out. When I stop at lights it will start to idle rough after a few seconds.
Any speculation on what this could be?
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 04-02-2008, 07:05 PM   #2 (permalink)
Favourite Bike: 02 Daytona 955i CE
Other Motorcycle: 1981 Yamaha 650(wife's)
Did you check your battery connections? Mine had the similar symptoms and ended up being the battery terminals were loose.
awegs955i is offline   Reply With Quote
Old 04-02-2008, 07:39 PM   #3 (permalink)
fivehundo's Avatar
I'll check.
I did have to mess with the Battery to put the battery tender on...
Old 04-15-2008, 02:09 AM   #4 (permalink)
fivehundo's Avatar
False alarm!
Just a bad tank of gas...
Happy birthday to me!!! :
Old 04-15-2008, 01:04 PM   #5 (permalink)
rickster's Avatar
How do you spell relief?
"The older I get, the faster I was".
rickster is offline   Reply With Quote
Old 04-15-2008, 07:29 PM   #6 (permalink)
Favourite Bike: 2000RS/02 Daytona motor
ckassen's Avatar
Other Motorcycle: 00 RM250
If it ever comes back...crankshaft pos. sensor.....
ckassen is offline   Reply With Quote
Old 04-17-2008, 05:50 PM   #7 (permalink)
Favourite Bike: 2006 Triumph 955i Daytona
Other Motorcycle: 2002 BMW R1150RT
Extra Motorcycle: 1998 Aprilia RS250GP1
A tankful of Techron fuel additive seems to clean them out as well.
This particular type seems to work better than others and I run some in a tank around every 10,000Kms followed shortly after by an oil change.
In Australia, you can get this under the Caltex brand. Hard to find outside of a Caltex Service Station.
I think that in the US, it's generally available, even in WalMart.
Linz
Linz is offline   Reply With Quote
Old 04-21-2008, 02:46 AM   #8 (permalink)
fivehundo's Avatar
...funny you should mention that.
It came back.
Can the crank sensor fail without tripping the check engine light? Aside from the bad performance, I've got no other indication.
Old 04-21-2008, 11:18 AM   #9 (permalink)
ckassen's Avatar
Mine did....If I remember correctly, no CEL...I happened to just have a crank pos. sensor in my extra motor and it worked.
Old 04-21-2008, 04:50 PM   #10 (permalink)
fivehundo's Avatar
I haven't even looked at the manual...
Is it hard to replace?
Engine may be running too hot sen098 T3 Sport / Touring Forum 8 02-15-2008 11:57 PM
T595 drama: weird engine and fork noises, weak battery... sevenpointsixtwo Daytona Deliberations 9 10-07-2007 09:49 PM
Help! Engine malf. light + weird noise kpp80202 Sprint Forum 9 07-12-2006 08:41 AM
Is my engine running hot? MercuryMan76 Triumph SuperSports 5 08-11-2005 09:23 PM
Weird stutter/loss of power after sustained running CaptainFlake Speed Triple Forum 8 12-07-2004 07:33 PM
