Well Jrelloway it should not cost to much to get the shop to do it.
It would only be 1/4 to 1/2 of labour and a front sprocket.
They may all so put a new lock washer on as well.
To do it your self you will need the "C" spanner if you have a single sided swing arm.
A large socket to undo the front sprocket nut (OTTOMH it is a 36mm) and a torque wrench a smaller 17mm socket to loosen and to adjust the chain.
You need to do up the 17mm bolt to 55Nm and the I think 36mm nut to 132 Nm
And have the chain with 35-40mm of slack.
This is the short version and just enough to give you the idea and not a step by step how to do.
If you have sold all or most of your tools I think that you would not have all the tools you need to do the job.
As I had to buy the larger socket and a bigger torque wrench and I have more than a few tools.
But never thought I would need truck size sockets to work on a bike.
