aye chingow!!!! 95 daytona 1200 con failing coils - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comHonda Powersports New Bonneville
Old 03-31-2008, 11:31 PM   #1 (permalink)
Favourite Bike: 1995 Triumph Daytona 1200
Kingjoey5000's Avatar
Other Motorcycle: 71 Honda Cb 500
Extra Motorcycle: Schwinn
havnt posted any thing in a while, but the coils on my 95 daytona, are all out of whack. hit them with the ohm meter today, and the were way outta spec. any body know where to get the best deal on some new coils????? and also some part numbers, the only go up to 1000 cc's on bike bandit. any help will be much appreciated, in the mean time ill have to put-put along on my 71 cb 500, **** life is just so hard.
Kingjoey5000 is offline   Reply With Quote
Old 04-01-2008, 09:24 AM   #2 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
Coil failure seems to have been a problem with the 1200. The shop where I bought my bikes has replaced two or three sets in the last year or so on high mileage bikes. I would be carefull about aftermarket or used parts and stick with your dealer. Once replaced, you should be good for a long time. I think there is an upgrade available through Triumph.
Brooksie is offline   Reply With Quote
Old 04-01-2008, 09:29 AM   #3 (permalink)
Favourite Bike: 2002 Trophy 1200
Other Motorcycle: 2008 Tiger
nology
Go to the Trophy site. I think I read the 1200 takes two coils and the 900 takes three. It seems to be a common problem.
joe tabler is offline   Reply With Quote
Old 04-01-2008, 12:24 PM   #4 (permalink)
Favourite Bike: 1996 Daytona 1200
daytonacharlie's Avatar
On Bikebandit the Daytona 1000 is actually the 1200. When the Daytona first came out it was a 1000 four and a 750 triple. Their parts list is correct for the 1200.
I've replaced my coils with ones from Nology, part #152 001 070T ProFire Ignition Coil Dual Outlet http://www.nology.com/profiremotor.html
dc
daytonacharlie is online now   Reply With Quote
Old 04-01-2008, 10:37 PM   #5 (permalink)
shatty coils
ordered one today, and picked up the other, the bike only cuts out when its hot out side and ive been riding for about 30-45 minuter at 70 or 80mph. im pretty pissed at my haynes manual though the specs it listed are not the same as the alleged broken coils on the bike, i shot resistance through the new one and it is the same as the old ones. i really could still see these as being the problem though. i think the reading i get on a cold coil and the hot broken one will be two completely different things. man that haynes looks to be way off the mark, any one else experience this with a manual?????
Old 04-06-2008, 01:38 PM   #6 (permalink)
coils all the way
every problem i have had with this bike seems to be fixed. it was all coil related for the past 3 months. i think it needs an oil change now. i hadnt driven it long enough to really break down the oil the engine want to stay revved up when i disengage the clutch, i picked up some oil but there is no place with a filter around opened on a sunday.shiiiiit.
Old 04-07-2008, 03:56 AM   #7 (permalink)
Favourite Bike: Daytona 1200 SE
Other Motorcycle: 1970 ISH/ Velorex
Extra Motorcycle: 1972 CB500
Just back off the idle adjustment and see if that helps. My brother put new coils on his Trophy and gained some idle speed once it was actually firing fulltime on all four. I find when I start I usually up it a bit to hold 1100 and then have to back it down once it warms up.
blkhrt81 is offline   Reply With Quote
failing ignition pick up coils????? adepackett Speed Triple Forum 12 07-13-2007 06:39 PM
seems easy, aye? crashcrawford Twins Technical Talk 4 02-09-2007 06:52 PM
Trophy 1200 coils etc Kremin Trophy 5 10-31-2006 03:34 PM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 01:25 PM
Daytona 1200 PVL coils scooty27 Daytona Deliberations 2 06-27-2006 07:32 AM
