Do want to know what it's geared for, or what it'll actually do? You can calculate the former using the primary, 6th gear, and final drive ratios, the tire circumference, and engine rpm. Mine worked out to be geared for approx. 191 mph at redline (11,500), but I know for sure it wouldn't do that even if you pushed it off a cliff. Now it's geared for approx. 172 @ 12,000 rpm. Hopefully I'll get to a track before I'm too old to see what it'll really do.
"The older I get, the faster I was".
