Oil leak/ complete oil dump - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 39 (permalink) Old 03-19-2017, 03:35 PM Thread Starter
Main Motorcycle: 2002 daytona 955i
So i checked the bike over after the winter and it all looked ok.
Started it up and It just decided to dump it's oil out after i started it,
Noticed it and shut it off but was running fine at the time, ran for maybe 10 seconds before i noticed it.
Then just continued to drain out till for quite a while.
The sand underneath was to soak the oil up to make it easier to clean up.
Not taken the fairing off and looked yet but from what i could see at the time all the oil was running off the oil filter, but i gues that's just because it's one of the lower points on the bike.
Needed an oil change anyway lol, just hope it's nothing major and i can find where it's coming from.
Name:	daytona oil leak2.jpg
lemmings999 is offline
post #2 of 39 (permalink) Old 03-19-2017, 05:52 PM
Main Motorcycle: '02 Daytona 955i CE
Other Motorcycle: '93 Suzuki GSX1100F
Extra Motorcycle: '78 XS750E
I guess I don't understand how it could be anything good?
First things that come to mind are:
Loose oil filter (like, REAL loose)?
Oil plug?
Oil pipe banjo bolts came out?
Cracked oil pan?
Hole in crankcase?
IanDMacDonald is online now
post #3 of 39 (permalink) Old 03-19-2017, 08:36 PM Thread Starter
Not sure as it was fine when put away before xmas and just emptied itself after being started up. It's not coming from the oil drain plug, and not running down it either,
I'm assuming that something has given under pressure, so hopefully just something simple as pipe to oil cooler? or filter itself has somehow given out?
It seemed to be running from the bottom of the filter.
Once i've cleaned the oil off the floor i'll put it on paddock stands and remove the fairing to get a better look and update then.
post #4 of 39 (permalink) Old 03-20-2017, 12:33 AM
Main Motorcycle: A Triumph
Wally's Avatar
Pull the filter and look for a split seam. Hopefully you didn't have straight water in it over the winter and crack the head or block.
Hangover likes this.
Wally is offline
post #5 of 39 (permalink) Old 03-20-2017, 08:16 PM
Main Motorcycle: Daytona T595
Hangover's Avatar
Could also just be the seal on the filter.
Hangover is offline
post #6 of 39 (permalink) Old 03-21-2017, 05:18 AM
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
What about the access nut for accessing the end of the crankshaft?
It has a rubber seal on it and if it comes unscrewed you will loose your oil like that. Remove the fairings and have a look.
cheers
DaveM
DaveM is offline
post #7 of 39 (permalink) Old 03-21-2017, 07:17 AM
cheers
DaveM
I'll remember that Dave. Thanks. One thing I learned about working on bikes is if I don't know what it is, or what it does, I don't touch it! There is an oil plug on my Yamaha that just looks like it wants to be unscrewed. Many have unscrewed it, and regretted it.
post #8 of 39 (permalink) Old 03-21-2017, 10:10 AM
Main Motorcycle: 2005 Daytona 955i
PaulM's Avatar
My monies on the hoses to the oil cooler.
PaulM is offline
post #9 of 39 (permalink) Old 03-21-2017, 11:11 AM
Main Motorcycle: Tiger Sport
Paul49's Avatar
Other Motorcycle: Tiger 800 XRx
Extra Motorcycle: Ariel Huntmaster
It's not another K&N filter is it?
Loads of them bursting leaks from that stupid welded nut.
Paul49 is online now
post #10 of 39 (permalink) Old 03-21-2017, 11:22 AM
Main Motorcycle: Thruxton R
Hm. Seems a bit serious. As others have said, check your filter for cracks or a dry seal. Check your pan for a break in the gasket. Examine the whole bike. Not familiar with the engine on your bike. Is it water cooled? If so, check your coolant for oil…
Sounds to me like something froze over the winter and let go.
69Bronze is offline
t120 oil not returning - rebuilt engine oskar866 Classic, Vintage & Veteran 29 03-31-2016 04:33 AM
Thruxton Oil leak 🤒 Blakethump Air Cooled Twins Technical Talk 8 03-29-2016 11:20 AM
1050 Oil Leak Near Water Pump KonaTheHusky Sprint Forum 6 02-09-2016 02:19 AM
2008 Triumph Bonneville Bad Oil Leak Upon Start Up smashingsly Air Cooled Twins Technical Talk 17 12-07-2015 09:38 AM
Oil leak - 14' with <3000 miles david CU Street Triple Forum 11 07-12-2015 07:50 PM
