Oil leak/ complete oil dump - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #21 of 41 (permalink) Old 04-01-2017, 02:34 PM Thread Starter
Main Motorcycle: 2002 daytona 955i
Unfortunately I dont have access to a propane torch.
lemmings999 is online now
post #22 of 41 (permalink) Old 04-03-2017, 08:11 AM
Main Motorcycle: Thruxton R
Go buy one.
Camp propane bottle and a screw on nozzle. Probably set you back 20 bucks tops.
They come in handy for all sorts of things.
Sent from my SAMSUNG-SM-G870A using Tapatalk
69Bronze is offline
post #23 of 41 (permalink) Old 04-06-2017, 09:32 AM Thread Starter
So the exhaust is now off, However 5 out of the 6 studs came out with the bolts.
From what i can find is this the correct part number for them, PFKL2037158? or is it T3100015?
Plus My ehaust doesn't appear to have any baffles inside, you can see straight through the can, Is that normal?
post #24 of 41 (permalink) Old 04-06-2017, 11:00 AM
Main Motorcycle: Tiger Sport
Paul49's Avatar
Other Motorcycle: Tiger 800 XRx
Extra Motorcycle: Ariel Huntmaster
Those part numbers are for the same stud, one is Lings part number, the 2nd is Triumphs part number.
Paul49 is online now
post #25 of 41 (permalink) Old 04-21-2017, 09:39 AM Thread Starter
So I've removed rad/oil cooler/exhaust, removed the oil filter, taken out the 17 sump bolts and the 3 around the oil filter, making a total of 20, (which i believe is all of them), however the sump itself doesnt seem to want to come off, there's no movement at all from it.
Have i missed something or is it gonna need a bit of force to remove?
post #26 of 41 (permalink) Old 04-21-2017, 01:57 PM
Paul49's Avatar
Usually a tap on the side with a rubber/hide mallet does the job once all the screws are out.
69Bronze likes this.
post #27 of 41 (permalink) Old 04-23-2017, 08:29 AM Thread Starter
So there's deffinately nothing else holding it on?
post #28 of 41 (permalink) Old 04-23-2017, 09:20 AM
Paul49's Avatar
post #29 of 41 (permalink) Old 04-24-2017, 11:39 AM Thread Starter
Any other ideas as it seems stuck, doesnt budge at all even with some tapping with a mallet
post #30 of 41 (permalink) Old 04-24-2017, 12:25 PM
Paul49's Avatar
On early sprint & sp3's there was a bracket with 2 bolts for oil cooler pipe on rhs. Dunno if you have that.
t120 oil not returning - rebuilt engine oskar866 Classic, Vintage & Veteran 29 03-31-2016 04:33 AM
Thruxton Oil leak 🤒 Blakethump Air Cooled Twins Technical Talk 8 03-29-2016 11:20 AM
1050 Oil Leak Near Water Pump KonaTheHusky Sprint Forum 6 02-09-2016 02:19 AM
2008 Triumph Bonneville Bad Oil Leak Upon Start Up smashingsly Air Cooled Twins Technical Talk 17 12-07-2015 09:38 AM
Oil leak - 14' with <3000 miles david CU Street Triple Forum 11 07-12-2015 07:50 PM
