Valve Shim Tool - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.comNew Bonneville
Old 03-31-2008, 04:17 PM   #1 (permalink)
Favourite Bike: 2006 Daytona 955i
Valve Shim Tool
Hi there everyone, I hope someone here can help me. Ive recently purchased a tool from Ebay to help change the shims on my D12. Has anyone used one of these, and if so how does it work? Id be grateful for any advice. Many thanks Spellbinder
PS Hope the pics show up
spellbinder is offline   Reply With Quote
Old 03-31-2008, 05:23 PM   #2 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
I have no idea what that is, nor how to use is.
I just use a magnet to pull out the shims.
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 12-07-2009, 02:41 PM   #3 (permalink)
Newbie
Arrow No Pictures
Your pctures aren't showing so can't give you any real advice.
If its the usual non triumph tool you use it to hold open one pair of valves so that the shims can be removed.
Turn engine so cam fully opens one pair of valves ie #1 cyl exh.
Bolt plate to to cam bearing caps and adjust legs on tool to hold down bucket on the respective valves when cam is rotated away from open position. Lever out shims and replace with correct size.
Don't forget to measure clearances before fitting tool. Keep a note of shim sizes fitted for later use.
With all due respect if you don't know what it is or how to use it I'd leave it alone as you can totaly f**k your motor.
Sell it to me for a bargain price instead.
guzzigeezer is offline   Reply With Quote
Old 12-07-2009, 03:46 PM   #4 (permalink)
Favourite Bike: 900 sprint
Other Motorcycle: 1200 daytona
just used one exellent tool easy to use
your best bet is to get triumph offial manuel as it shows you how to us it not haynes
any probs give me a shout
bjbiker is offline   Reply With Quote
Valve Shim Removal Tool? Wychall Hinckley Classic Triples 17 03-22-2011 04:58 PM
Valve Shim Removal Tool Tassie_Tiger Tiger Workshop (archive) 9 12-10-2007 09:55 AM
Valve Shim Removal Tool Bluetiger901 Maintenance & Workshop Talk 1 01-15-2007 01:34 PM
valve shim tool 955 malc Tiger Workshop (archive) 9 09-27-2006 12:20 PM
