Spark Plug Change, Airbox question??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-28-2008, 09:38 PM   #1 (permalink)
Favourite Bike: Now, Daytona 955
Other Motorcycle: 96 CBR F3
I am changing the plugs. All three looked good but hopefully this is whats causing the hesitation below 4k. Now on to the question. When I pulled off the airbox there are three hoses on the bottum. As seen while sitting on the bike, the far left one goes to the ECU, the middle one (larger) goes to the far lower left side of the engine crank case cover, the last line on the far left is a tube about 8 inches long that just hangs from the bottum of the airbox not connected to anything. My question is is it suppose to connect to anything or just hang? I can not see any missing line or connector for it.
Thanks,
Komodo
Komodo is offline   Reply With Quote
Old 03-28-2008, 10:13 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Komodo, That's the airbox drain. I noticed on the ZX6 here that there's a small bottle attached to the airbox's drain hose. I think I'll get one just to seal up the airbox a tad.
Brad
Old 03-28-2008, 10:33 PM   #3 (permalink)
Thanks... I thought that was the case but wanted to ask the experts....
Better to be safe and ask then sorry and miss something... LOL!!
Old 03-29-2008, 10:09 AM   #4 (permalink)
Komodo, I also had experienced hesitation at low revs and some difficulty starting the bike after it sat overnight. I started using strictly 89 octane, after reading another post on this site, and I no longer have hesitation or hard starting issues.
NotADuc is offline   Reply With Quote
Old 03-29-2008, 10:57 AM   #5 (permalink)
Favourite Bike: '98 Daytona
Wally's Avatar
Other Motorcycle: '64 T120 in pieces
What octane gas were you using?
Wally is offline   Reply With Quote
Old 03-29-2008, 03:43 PM   #6 (permalink)
I was using primarily Shell V-power 93 octane but atleast 92 octane if I didn't fill up at a Shell station.
Old 03-29-2008, 09:36 PM   #7 (permalink)
Thanks for the help. I went ahead and swapped the plugs out. Ran it all day today. Its like a new bike.
Spark plug change? Alekker Triumph SuperSports 8 05-22-2007 09:20 AM
Spark Plug Change Alekker Triumph SuperSports 2 07-18-2006 01:20 PM
Daytona t595 '98 spark plug change Daytona Deliberations 0 01-28-2005 11:54 AM
Any hints for a spark plug change? jhusman Hinckley Classic Triples 30 01-25-2005 11:28 AM
Airbox & center spark plug Adventurer & T-Bird crockabull Maintenance & Workshop Talk 2 01-23-2005 09:48 AM
