What map do I have - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 02-17-2017, 02:15 PM Thread Starter
Main Motorcycle: Speed Triple
Gazmo65's Avatar
What map do I have
I have a 2001 955i Daytona with the DSSA and the VIN starts 133XXX, I connected Tuneecu today and had a fault code PO135 oxygen sensor, I cleared it and it hasn't returned, but i also checked which map was loaded and found it to be 201205 but can't find this in the Tuneecu library. I have an end can that I'm going to fit, just waiting on a link pipe so I was thinking of uploading the massive midrange 3 tune but not sure where to start due to the existing map, any ideas?
Mods if this is in the wrong section please move it to the correct section
Gazmo65 is offline
post #2 of 9 (permalink) Old 02-17-2017, 03:12 PM
DEcosse's Avatar
a VIN starting 133xxx and a DSSA is a 2002 model regardless of whether it was manufactured in 2001 - you would be better just calling it a 2002, which will avoid any confusion when identifying it
That map number makes no sense regarding OEM convention - possibly is custom - 201205 sounds like a 'date' reference (may 2012)
Your map for an MC1000 ECU should begin 10XXX
DEcosse is online now
post #3 of 9 (permalink) Old 02-17-2017, 07:40 PM
Main Motorcycle: 2005 Daytona 955i
PaulM's Avatar
The Julian map works very well with an 02 Daytona last one on the list for the Daytona see here.
http://www.tomhamburg.net/Custom_Tune_list.html
PaulM is online now
post #4 of 9 (permalink) Old 02-17-2017, 08:05 PM Thread Starter
Gazmo65's Avatar
Cheers will have a look at that, I will also try to get more info on the tune already loaded tomorrow and see if I can upload some screen shots.
Gazmo65 is offline
post #5 of 9 (permalink) Old 02-18-2017, 01:21 PM Thread Starter
Gazmo65's Avatar
http://www.triumphrat.net/album.php?...ictureid=73921
http://www.triumphrat.net/album.php?...ictureid=73929
Here are 2 screen shots one showing the map number and the other showing the actual map, I don't know if anyone can look at it and compare with any standard maps, as I'm not sure how to do this with the Android system.
Gazmo65 is offline
post #6 of 9 (permalink) Old 02-19-2017, 09:09 AM
PaulM's Avatar
That map is a non standard map its richer than the Julian map I use and not as rich as the MM3 so what it is I'm not sure, someone's one-off probably.
PaulM is online now
post #7 of 9 (permalink) Old 02-19-2017, 09:38 AM
Main Motorcycle: Triumph Daytona 955i
Dai-San's Avatar
TBH mate, it really doesn't matter what map you have if you're going to try another one, just make sure you back it up before uploading the new one then you can always go back to it.
Dai-San is offline
post #8 of 9 (permalink) Old 02-19-2017, 03:46 PM Thread Starter
Gazmo65's Avatar
Cheers PaulM I just wanted some feed back so i know what I'm starting with. Dai-San I just needed a starting point, now I've had some feed back i will be extra careful with the current map before trying any other. The bike is currently using the standard pipe and I'm looking at using a different mid pipe and end can, so i will probably try this without changing the map.
Gazmo65 is offline
post #9 of 9 (permalink) Old 02-23-2017, 11:12 AM
PaulM's Avatar
Hi Gazmo65, Your bike probably had a free flowing can of some sort one it before you bought it, the previous owner probably swapped to a standard can sold the bike and then sold the other one happens all the time. Doubt if it will run well with that tune and a standard can they normally run run a bit flat with a standard can and a sports type tune. You can save the tune on tunecu and try a standard oem tune. See here http://www.tomhamburg.net/Tune_List.html
PaulM is online now
2013 Thruxton EFI Map Question ctmtb Air Cooled Twins Technical Talk 4 07-02-2016 10:30 PM
Inexperienced: Triumph Accessory Mufflers and New Map kslaggs ECM and FI Tuning - Help, Tips & Tricks 3 03-17-2016 07:34 AM
New Exhaust (TORs) and Map on 2014 Thruxton kslaggs Air Cooled Twins Technical Talk 2 03-14-2016 03:12 PM
MAP verses Morgo 750 kit sportsprint Classic, Vintage & Veteran 7 12-05-2015 08:01 PM
Fueling map issues? mangosmoothie ECM and FI Tuning - Help, Tips & Tricks 12 04-06-2015 12:02 AM
