Concerns about seal replacement on 02 Tona - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismSportbikeTrackGearMotorcycle.comHonda Powersports
Old 03-11-2008, 08:53 PM   #1 (permalink)
Favourite Bike: 02 Daytona 955i CE
Other Motorcycle: 1981 Yamaha 650(wife's)
I finally changed my front sprocket on the Tona. I went to a 17 tooth on the front. I haven't been able to really gauge the improvement because its still 30+ degrees here in the cold north. I did take it down a couple streets that werent covered in ice yet.
BUT.... I have a concern. While replacing my defective front outer main shaft seal, I punctured the inner seal. I started it up and let it run for a bit before I put the new outer seal on and I didn't see any leaks. SO I put on the new outer seal and finished the job. Should I be concerned about it? Any advice would be appreciated. Thank you.
Andy
awegs955i is offline   Reply With Quote
Old 03-11-2008, 09:36 PM   #2 (permalink)
DEcosse's Avatar
Originally Posted by awegs955i View Post
... While replacing my defective front outer main shaft seal, I punctured the inner seal. I started it up and let it run for a bit before I put the new outer seal on and I didn't see any leaks. SO I put on the new outer seal and finished the job. ...
I'm not sure what you're talking about here - there is only ONE seal:
there's the bearing (24), the circlip (25) then the seal (26) - just one!; the sleeve (27) and the sprocket (28) lock washer (29) & nut (30)
T'Rat.net BOTM November 2009
Old 03-11-2008, 10:25 PM   #3 (permalink)
re-prasing post
I stand corrected. I punctured the backside of the bearing housing #24. It looked plastic like the outer seal was. I Assumed that it was a seal. Anyway... that being said. Should I be concerned that I poked a hole through the back of that bearing case? Or should I just leave it?
Old 03-12-2008, 12:27 PM   #4 (permalink)
DEcosse's Avatar
I wouldn't worry about it - should be fine.
A tip I learned for pulling the seal to avoid scratching up the sealing surfaces (or the bearing) - insert a couple of self-tappers 180 deg apart into the face of the seal then grab the heads with some vize grips or pliers & pull it out.
Old 03-12-2008, 02:11 PM   #5 (permalink)
seal
Decosse-
I did what you recommended,except I went in too far with the screw,thats what poked the bearing housing. Right idea,just went a little too far.
Thanks
fork oil seal replacement. 68tri Maintenance & Workshop Talk 2 09-14-2006 06:03 PM
Fork seal replacement kjartan Triumph SuperSports 3 07-14-2006 07:51 PM
fork seal replacement psds Classic, Vintage & Veteran 9 06-08-2006 07:29 PM
fork seal replacement- 99 S3 grunt11b40x Speed Triple Forum 0 10-30-2005 11:45 PM
Clutch Pushrod Seal Replacement? SoCal Maintenance & Workshop Talk 1 05-03-2004 02:55 PM
