Motorcycle.com
Old 02-28-2008   #1 (permalink)
To buy?
I am looking at a 98 595 with 5k on it. i havent owned a triumph but have numerous other bikes both jap and euro. a good friend of mine has it in his basement and there is one small problem with it.
the last time he took it out (which was 3 or 4 years ago) he stopped at the gas station at the end of his street and shut it off to fill up. when he turned the key back on nothing happened. no lights, no electronics, no nothing. he pushed it home and went out and bought a new aprilia tuono. so there is has sat for that long. he just had no interest in messing with it. i know that he is very meticulous with his stuff and if it is an easy fix it could be a hell of a deal.
does anybody here have a clue what the problem could be (other than the obious stuff like battery, fuse ect)?
Thanks for any info you can provide!!!
cpettit is offline   Reply With Quote
Old 02-28-2008   #2 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
cpettit, Welcome to the forum. More than likely you'll, at minimum, need to install a new quality battery, drain the gas, a coolant flush and oil/filter change. Tire age has to be suspect in my book. If it died just after running and hadn't been put away for three years I'd check the 40 amp fuse.
More comments will follow, I suspect.
Brad
Old 02-28-2008   #3 (permalink)
Favorite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: Triumph Daytona CE
Extra Motorcycle: Husqvarna SMR 450
That would be my guess...
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is online now   Reply With Quote
Old 02-28-2008   #4 (permalink)
thats the kind of info i was looking for. i was already counting on tires, fluids ect but the electrical issue is what i am pondering. are there any major mechanical differences in the 595 and the 955? power, suspension, brakes? the only mod that i know of on this bike is a leo vinci high mount slip on.
Old 02-28-2008   #5 (permalink)
Favorite Bike: Triumph Sprint ST
Other Motorcycle: Suzuki DRZ400E
It could just be a broken wire.
Mine did the same and it was the wire to the ignition switch. Once the bike has been started the power relay keeps everything going. Once you shut off the relay clicks off and won't start again because there is no power to it. The offending wire was in the connector on the end of the ignition switch wire where it plugs into the main loom on the right hand side of the fairing. It gets pulled by the steering.
Lucky I was at home but it took a fair time to work out what the problem was.
I know I have an '02 but I beleive the set up is similar to the earlier ones.
DaytonaDave is online now   Reply With Quote
Old 02-28-2008   #6 (permalink)
fivehundo's Avatar
In 2006, the last model year for the 955i, the bike had 149 horsepower. The 1998 T595 had 130. While 20 horsepower is fairly substantial, I wouldn't let it hinder you from scooping up a good deal on a T595.
There are a lot of differences between the two bikes. First of all, they won't use the same ECU and a lot of the other electronics are dissimilar, the dash is not digital on the T595, the newer 955i is about fifteen pounds lighter, the exhuast systems are different and unless you get the 1999 or 2000 955i, the bikes look nothing alike.
Also, weren't the T595s notorious for loosing 4th gear? I remember reading that somewhere...
Old 02-28-2008   #7 (permalink)
bradtx's Avatar
"Also, weren't the T595s notorious for loosing 4th gear? I remember reading that somewhere..." fivehundo
Changeover was at VIN 57946. My '98 is beyond that with a 1/1998 build date for a quick comparison.
Brad
Old 02-29-2008   #8 (permalink)
Favorite Bike: 08 Thruxton
Other Motorcycle: BMW R1200RT
Extra Motorcycle: Honda Silverwing
As Fivehundo said, there's a significant amount of difference between the 595 and later 955s.
Having said that I agree that the extra power isn't that big a deal. From experience (And what I've read) the extra power's towards the top end of the rev range and the earlier bikes have plenty of grunt where you're most likely to use it.
I'd say go for it and grab yourself a bargain. Sounds as though it could be a relatively easy fix with a lot to gain at the end of it.
Bought a new Tuono as a result? Your friend's got too much money...
Navy Boy is offline   Reply With Quote
Old 02-29-2008   #9 (permalink)
good job + no wife or kids = money for self.
I am goin tomorrow to look at it. Hopefully i will be a triumph owner soon.
Old 02-29-2008   #10 (permalink)
fivehundo's Avatar
What's he asking for it?
Had to buy one! robmiller Sprint Forum 8 06-11-2007 08:15 PM
Which Would You Buy? beagldog Twins Technical Talk 7 04-24-2007 10:04 PM
To buy or not to buy, that is the question tony2 Sprint Forum 11 07-02-2006 08:11 AM
To buy or not to buy MonkeyNuke Sprint Forum 3 04-29-2006 07:59 AM
What to buy dtulloch Club Cafe 13 03-31-2005 08:30 AM
