Progressive Insurance
CycleGear.comMotorcycle.comMotorcycle.com Classifieds!TriumphPerformanceUSAShopTriumph.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comSpringfield Armorybritishcustoms
Old 02-18-2008   #1 (permalink)
Favorite Bike: Triumph Sprint ST
Other Motorcycle: Suzuki DRZ400E
Speed Sensor Magnet
I have had the dreaded failure of the speed sensor magnet.('04 Tona) (Probably my fault because I wasn't careful enough lining up the drive when I put the wheel back in.)
It was broken in two. I have stuck the ring magnet back together with epoxy. (After degreasing of course.) The question is have others done this ? if so did it work and did it last ?
As we know from previous threads a replacement is fearsomely expensive.
DaytonaDave is offline   Reply With Quote
Old 02-18-2008   #2 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
Dave, Iffy fix, but works often enough to at least try. Ended up replacing the unit on the '02 which was broken prior to it's arrival. Good luck!
Brad
Old 02-20-2008   #3 (permalink)
On reflection I decided to buy a replacement - £92 + VAT Much to my surprise the expected diamonds and gold plating were nowhere to be seen it was just the same old plastic moulded thing as the old one.
Peace of mind is priceless. I know it is only the speedo drive but if I used the glued up one I would be riding along staring at the speedo expecting it to pack up any minute. A little distracting to say the least.
Old 02-21-2008   #4 (permalink)
Favorite Bike: Custom Daytona
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Extra Motorcycle: SV650S
You're not alone 'Dave - it's really disappointing that Triumph has not made the magnet available as a separate spare part. Now after you've been there, sure not to again, but it is a tough lesson to bare at that price ...........
GSXR 1000 Front End Swap
Suzuki TL1000S................Suzuki SV650S.............Triumph Daytona
http://www.triumphrat.net/image.php?type=sigpic&userid=2434&dateline=1225242  733
No magnet in drain plug? BrianM Twins Technical Talk 9 11-27-2007 07:49 AM
O2 Sensor DBS The Rocket Science Forum 1 02-02-2007 11:50 PM
Need a little help with the O2 sensor.. rudebwoy85 Speed Triple Forum 6 12-11-2006 08:55 AM
O2 Sensor BUCKET Speed Triple Forum 15 09-11-2006 07:14 PM
Drain bolt magnet question keef Twins Talk 34 07-03-2006 09:37 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
