Engine stall-out/Shut-off at stop light/stop sign??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-30-2008, 01:59 PM   #1 (permalink)
Favourite Bike: 11 Speed Triple
jrelloway's Avatar
Other Motorcycle: 07 Daytona 675
Extra Motorcycle: 99' Daytona 955i
Hey guys, I don't know what it going on, but I just got my bike back from the shop. Tons of things needed to be done ( in short, new cylinder head, Connecting rods, Crankshaft, seals, gaskets, etc...). So I got it back and I'm having a problem with the bike. It used to do this before I had to take it to the shop which was a completely unrelated issue, but when I pull up to a stop sign, or stop light, my engine all of a sudden cuts out. I don't know why it does this but I have to restart it then seems to be running just fine again. It's like when the engine slows down, it doesn't stop at 1000-1500RPM to idle, it just keeps goin down till it shuts off.. even while Im at an idle speed for 30-45 seconds, it all of a sudden just does it. I hooked it up to my TuneBoy and looked at the settings and everything seems to be in order. And I can't replecate the issue in a parking spot, only when I pull up to a stop light or stop sign. Any clues as to why it's doing this?
jrelloway is offline   Reply With Quote
Old 01-30-2008, 02:43 PM   #2 (permalink)
Favourite Bike: 2004 Daytona 955i SE
Other Motorcycle: 1995 Daytona 900
Fuel Injectors
Your issues sounds similar to a friends 955i. When riding to a stop, the bike would just shut down. He had the problem diagnosed as bad fuel injectors. After having a few replaced, the bike ran fine. I've heard fuel injectors were a common problem on early 955i engine equipped Triumphs.
Might be a good place to start looking.
Good luck.
-Scott
Research Rat is offline   Reply With Quote
Old 01-30-2008, 03:33 PM   #3 (permalink)
Favourite Bike: 2001 D955i
silver955i's Avatar
Other Motorcycle: 2005 Harley Softail Herit
I second that.......I bought an '01 955i with only a 1,000 miles on it and it did the same thing........ran a couple of tanks of high test through it with fuel injector cleaner.....good as new. Worked for me anyway.
silver955i is offline   Reply With Quote
Old 01-30-2008, 11:35 PM   #4 (permalink)
Favourite Bike: '01 Daytona 955i
Witch955i's Avatar
Other Motorcycle: '02 Kawa Vulcan 800
Extra Motorcycle: Kymco 250 Grand Dink
I have about 10K on my '01 955, and have not had that problem, but Silver's post made me wonder if you're using the recommended 89 octane? I really don't know how the octane would affect the injectors, though. Probably too much in town riding!
Witch955i
Witch955i is offline   Reply With Quote
Old 01-31-2008, 05:19 PM   #5 (permalink)
Favourite Bike: 2001 Daytona 955i
Other Motorcycle: 2006 Sprint ST 1050
My bike has done this also!
This is my second 2001 Daytona 955i.
I never had this problem with my bike back in Texas. I bought the same bike here in Austria and have had this problem more than a few times now.
I have been wanting to buy some injector cleaner to pour in the tank but have not gotten around to it as I only rode it for the first time this year yesterday. My first thing this weekend will be to buy some injector cleaner!
But if anyone has any more on this problem, I'm listening...
quicksilver is offline   Reply With Quote
Old 01-31-2008, 09:00 PM   #6 (permalink)
Favourite Bike: 2005 Daytona 955i
I had this same thing happen to me last year. As best as I could tell, it was bad fuel.
I was out riding one day and running low on fuel. Of course, the only station around was a BP. I hate BP! I normally won't even use it in a lawn mower, let alone my bike. So I only filled it enough to get back home. Next day, I try to take the bike out and it dies at every stop. I spent the whole day trying to figure out what was wrong. Finally, I just went and got a gas can full of Sonoco 93 and poured that in. Problem solved.
I don't know what it is, but all of my vehicles seem to run better on Shell or Sonoco vs anything else. Every vehicle I have ever owned has at some time had a bad experience with BP. You would think by now I would know better...
miroslav is offline   Reply With Quote
Old 02-01-2008, 03:26 AM   #7 (permalink)
i read that this issue pertains to a bad earth in the connector block someplace on the bike,im sure i read it in one of the known recall issues.
im buggered if i can find the link to it now,ill keep trying to see if i can reaquire it
Simmox is offline   Reply With Quote
Old 02-01-2008, 03:16 PM   #8 (permalink)
I don't think it is a grounding problem...
If there were a grounding problem causing the stalling then the bike would also stall running at higher rpm's and running down the road at speed and not just then when you come to a stop laying off the throttle. I am not a mechanic but this is just my personal oppinion. I would rather think it would be the injectors not spraying perfectly at idle. I will let ya'll know if I cured the problem with injector cleaner in the tank. But it might take a week or so seeing as how the weather around here is crap!
Ouch! Idiot ran stop sign Ouch! yakoo11 Triumph SuperSports 25 10-04-2008 04:42 PM
Engine Stop Switch oldndumb Sprint Forum 25 05-29-2007 08:58 PM
Engine will stop when riding in the rain Lainer Twins Technical Talk 31 01-03-2007 07:42 PM
Engine cutting off at stop lights Stoudty Hinckley Classic Triples 4 06-23-2006 01:56 AM
Engine temps in stop and go traffic kaosj Daytona Deliberations 3 03-30-2005 08:27 AM
