Old 01-14-2008   #1 (permalink)
Newbie
Daytona 955i - Speedo probs
Hi, i have just bought an 02 - 955i, (9,000 miles)...
I have a question, has anyone had problems with the speedo 'sticking' occassionally? -if so any tips on how to remedy this?
Thanks in advance...
I'm new to the forum and am just finding my was around, so apologies if this has been in topic else where..or if i'm asking in the wrong place..
Cheers
L'Raine
Raine is offline   Reply With Quote
Old 01-14-2008   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
When you say 'sticking' can you clarify?
Does the digital speed reading remain at zero, but also sometimes works normally?
That scenario is a symptom of a low battery voltage. There is however an updated ECM program from your dealer that disables the Speed Sensor Error Check and will not exhibit this issue. Check out your battery however.
GSXR 1000 Front End Swap
Old 01-14-2008   #3 (permalink)
Favorite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: Triumph Daytona CE
Extra Motorcycle: Husqvarna SMR 450
Originally Posted by Raine View Post
...any tips on how to remedy this?
Yeah...
...Don't!
First of all, there is a degree of inacuracy in my speed-o anyway, so it can't be trusted.
Second, it might give you a little bit of a leg up on a cop that catches you doing 10 over. If he's a rider, he might let you slide if you tell him it's broken.
Third, (and probably the most "Shady" reason) your odometer doesn't clock off miles as fast.
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 01-16-2008   #4 (permalink)
Pull the wheel off and clean and regrease the speedo hub, It may be dry or packed with old crap and stiff grease.
Second, check the hub wiring all the way back to the harness for any signs of kinking, cracking, pinching, or rubbing that may have damaged a wire inside.
Good luck!
Pinballer is offline   Reply With Quote
'02 955i / Wisconsin / Speedo / Resetting (cycle) wwpageiv Daytona Deliberations 0 06-05-2007 10:03 PM
daytona 955i/speed triple 955i luggage differences? LOWEY Daytona Deliberations 0 01-01-2007 01:47 PM
Daytona 955i(1050?) or Daytona 675? qc415 Daytona Deliberations 19 12-05-2005 10:28 AM
Tiger 955i Probs with rear brake ? Tiger Workshop 7 06-05-2005 03:17 PM
Tiger 955i Probs with rear brake ? Tiger Workshop 2 05-25-2005 04:29 AM
