Originally Posted by silver955i
I bought a 2001 955i about 3 months ago with 2,000 miles on it. Not sure of maintenance history. I just completed the first oil change since I had the bike and I found what appears to be metallic particulates in the drained oil. Here's the kicker.....they are a copper color and do not respond to a magnet. Check out the picture I have attached............any thoughts on this one. I can see if it was silver metallic and perhaps the oil was never changed after run-in, but copper color????
Well, I can't see the picture (must mean you used photobucket since I can't see it at work)...
Aluminum soaked in oil can sometimes appear to have a copper-ish hue. Also, if it gets heated up enough, it can change colors into pretty much every color of the rainbow. It would also not respond to the magnet.
Probably aluminum...
