AdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 11-26-2007   #1 (permalink)
Favorite Bike: Daytona 955i 2004 Se
Nickwiz's Avatar
Other Motorcycle: 1200 Daytona 1995
Extra Motorcycle: BSA Starfire 1968
Blue Flames
Was riding back from the Bike show in Birmingham last night with Mrs Nickwiz in tow and she says that my 955i was occasionaly emitting pretty blue flames from the exhaust! Now I don't have a blue flame exhaust fitted before the wisecracks start!
I think it means the bike is overfuelling. Does that mean I need the ignition or injection tweaked? I'm great with carbs but EFI stumps me. Or is it fine and I shoulsd just enjoy the pyros. I have a carbon can co race pipe fitted.
it takes a better rider to ride an old slow bike fast than a new fast bike slow!
Old albums: http://www.triumphrat.net/photogalle...m792/album634/
New albums: http://www.triumphrat.net/memberalbums/useralbums.php
Nickwiz is offline   Reply With Quote
Old 11-26-2007   #2 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
Nick, The '04 D955i used to be pretty bad WRT backfiring regardless of tune or can. When I changed plugs to help with my cold starts, the backfiring went to near zero...no idea why.
A couple of contributing factors are one, there's no decel mode in the ECU like most EFI cars with a manual trans and two, the '04's idle is set at 1200 RPM, just a tad lower than the other two.
The only case of backfiring while not on overrun cleared with a new tank of gas.
Brad
Old 11-26-2007   #3 (permalink)
Nickwiz's Avatar
Sounds like its prety normal then. So I'll just enjoy the Fireworks I guess!
Old 11-27-2007   #4 (permalink)
Favorite Bike: My '04 Sprint-ona
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Blue flames
My ST used to do similar on over-run. In my case it was because a little air was bleeding into the pipe at the join between the can and the main pipe.
The slot cut in the can pipe end to allow it over the main pipe was a little longer than the amount that could overlap, leaving a little square hole for the air to get in.
Have a quick check for something similar
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 11-29-2007   #5 (permalink)
Favorite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: Triumph Daytona CE
Extra Motorcycle: Husqvarna SMR 450
Modern Ferraris do that as well. So does my roomate's Factory Tuono.
It actually means your engine is pretty well dialed as far as your fuel system is concerned.
Let me ask you this: When the flames come from your pipe, can you feel a loss of power for a second?
If not, you're good...
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 11-30-2007   #6 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
Same on 2004 Sprint
Nick,
I have an '04 Sprint ST with a Triumph SS race can and my buddies I ride with tell me that I emit flames at times, this is only when I am going for it (which is frequently).
I have the latest off road tune and run a K&N air filter as well.
I think on the 955 this is normal.
Rexx is on the money too I believe.
cheers,
DaveM
flames from exhaust sweatmachine Twins Talk 7 12-13-2006 10:56 AM
Anyone have the Black Rocket with tribal or flames? RidinSunshine The Rocket Science Forum 12 10-05-2005 11:09 AM
05 red/gold flames R3 Torch The Rocket Science Forum 6 09-28-2005 10:14 AM
Flames and more RocketVet The Rocket Science Forum 19 08-09-2005 04:58 PM
My bike is trying to burst into flames!! Daytona Deliberations 8 09-17-2004 06:22 AM
