So here it is a 2002 showing 18,000km (11,000 miles for you Americans) showing on the clock, no way of knowing if this is correct or not but this is what I know
It runs OK as its winter here I only got to 3rd gear
Body work needs some repair and MUST be returned to original Aston racing green
Wheels need to be black
rear sets need to be same color as frame
need to do the usual
compression test
valve gap if above is good
hoses
brake lines/ brakes if required
fork oil
I am looking for a bit of advice to set up a plan to get this thing looking and running as it should any advice would be greatly appreciated
Hmmm can't embed a youtube video any other way
https://www.youtube.com/watch?v=TjQezUF03zM
compression test
hoses
fork oil
