my 955i won't start...The starter ist runing, but the fuelpump is dead.
Here's the problem: I've got no light switches etc. because i changed them against a electronic which controlls the main functions of my bike in combinations with push buttons.
Are in the light switch etc. any connection that are needed ?
I also cut out the digital gauge, but in the past my bike was running without the gauge.
Which relais are needed to run the bike only the ignition relay an the main relay ? Maybe i cut out to much...:|
Lights don't matter, neither do instruments
The main relay needs to be on - you should have 12V at Fuses 6 & 7
From the original key-switch connector,(Main Harness side) the Green Wire which feeds to Fuse 5 should 12V
You're a bit vague on what you have modified/eliminated - you must also have the interlock loops connected at the Alarm connector
You say starter runs so it appears that you have power at Fuse 5 - when you turn on the Kill/Run switch, do you hear the pump run for ~ 3 secs? (It should continue to do this repeatedly if you turn to Kill, then back to run again)
No, the pump dosen't run at all...It makes no sound, when i feed the pump directly with 12V it runs.
Okay, i'll check it tomorow, but i've checked the fuses already and they're alright.
The main power relay dosen't make any click, clack or how you call the sound of a relay, when i turn the key.
The ignition relay pulls, when i turn the key or use the kill switch.
I cutted all cabels the weren't longer required, so i wonder that the pump is dead.
Yes, the loops are in their places.
Is it possible the ECM don't get the 12V ? Which pin on connector plug is used for it, 2/F3 ?
Which pin of the main power relais shoul have 12V when the key is turned on or not...?
Sorry, my english needs a little bit of lubrication...
I'm not asking you to check the fuses (to see if they are blown) but to measure to see if you have voltage at the fuses - that will tell you whether the relay is operating or not
12V 'IN' to ECU is 2/E1 - you can also measure this voltage at the Fuel Pump connector and also at pin 1 of the Alarm connector.
If you do not have 12V at Fuse 6 & 7, then relay is not turning on
Are neutral and oil pressure lamps lit? Edit - you say you removed the gauge - do you have an alternative to indicate these?
Those lamps would be a good indicator of whether your ignition power circuit is complete.
Otherwise measure for 12V at the wire loops on the bypass connector (with it plugged in) - you should have 12V on pin 1.
If that is good, it would suggest you should have power to 2/E1 which should activate the ECU to send the 'low' signal (yellow/brown) to the Power Relay to turn it on.
It sounds like it could be - rare though - you should check to see you definitely have 12V at 2/E1
(also check your grounds to the ECU are good! - check that you those terminals on the ECU have continuity to ground)
Correct
The first group should go directly to the Engine Ground Point
Question - when/how did this problem begin? If this only started after you modified the wiring, it is unlikely to be an ECU failure but something you have done in the harness.
So, yes, check that all those points have a connection to either engine ground or battery negative and also that the 12V does indeed make it to 2/E1 (you can measure for continuity between 2/E1 and the Bypass Connector Pin 1)
Yes, it started after my work on the harness...But I don't know what i could have done...
May be i can check it tomorow...
Thank you so far...
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
