AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 09-05-2007   #1 (permalink)
Favorite Bike: 2001 D955i
silver955i's Avatar
Other Motorcycle: 2005 Harley Softail Herit
Popping from Hi mount CF exhaust on decel???
I have a 2001 Triumph Daytona 955i.....2100 miles on it....Triumph factory hi-mount CF exhaust. The most recent download was done at the Triumph shop for that pipe. I still getting a lot of popping on decel at all RPM's. Any thoughts??? I wouldn't call it back firing just ..popping.
silver955i is offline   Reply With Quote
Old 09-05-2007   #2 (permalink)
Favorite Bike: 2006 Daytona 955i
normally a result of the secondary air injection fitted, you need a tune that takes that into account or disable it, it chucks air into the exhaust at certain revs and under throttle shut down, effectively burning excess fuel in the exhaust for emmissions, but the result is pop pop
Colin955Devon is offline   Reply With Quote
Old 09-05-2007   #3 (permalink)
Favorite Bike: '03 Daytona 955i
HiDesert's Avatar
Glad you asked; I've been meaning to ask the same question about my '04. And you're spot on; it's not a backfire, just a pleasant burble. I actually kind of like it.
In the third century B.C. the Greek stoic philosopher Chrysippus died of laughter after giving his donkey wine, then seeing it attempt to feed on figs.
HiDesert's ride photos
HiDesert is offline   Reply With Quote
Old 09-06-2007   #4 (permalink)
silver955i's Avatar
Does an '01 have a secondary air intake. Is it better to disable or re-map?
Will disabling create other problems?
Old 09-10-2007   #5 (permalink)
tri955i's Avatar
popping
I don't normally respond too much as I am new to triumph bikes and thier tendencies,but.....brother's Ducati( same principles ) is under going some serious work now, been fighting a "popping" in the exhaust for a year.It has just developed into a complete valve job as the ECU chip was running lean at times and took out the intake valve in the vertical head.
Faster, faster, faster, until the thrill of speed overcomes the fear of death…
My Bike: 2004 Triumph Daytona 955i with Trident Wolf Exhaust
tri955i is offline   Reply With Quote
Old 10-07-2007   #6 (permalink)
Favorite Bike: S1 Lightning
Other Motorcycle: '96 FXDL
Extra Motorcycle: DRZ400S
Depends on what market it was built for, but I believe most don't. Look at your valve cover; if it's got some busy stuff on the front it has it. If you disable I beleive you'll need to remap.
Engines do it naturally, it's nothing to get worried about.
I too enjoy the sound of an engine on deceleration. My 'tona cuts off the fuel when decelerating with the throttle closed. Fuel gets restored as the engine falls below 3,000 rpm; it's a joyous sound!
Hard to know exactly what people mean by 'the real world'. Whatever it is, this is the primo sports bike for it. Plenty of everything and that triple howl! Sept 03 T.W.O.(Triumph Daytona955i)
02Daytona955i is offline   Reply With Quote
Causes of Backfire/popping on Decel rstover Twins Technical Talk 8 03-28-2007 07:01 PM
Popping during decel oregonthruxton Twins Technical Talk 11 03-15-2007 03:44 PM
jetting issues and decel popping tcb Twins Talk 11 06-02-2006 06:14 PM
Popping during decel PolockJoe Twins Talk 17 04-13-2006 10:30 PM
'02 - '04 Sprint Decel Popping? cafetbird Sprint Forum 7 04-04-2006 02:31 AM
