Lifting a SSSA caution - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comOntario TourismHonda PowersportsMotorcycle.com Classifieds!
Old 08-29-2007, 05:31 PM   #1 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Hi All, I had the rear on the Triumph paddock stand with the rear wheel removed. While using a jack under the header pipe to get the front wheel off the ground I almost dropped the D955i on me (literally) as the right side of the stand came off of the garage floor.
As I've jacked up the front numerous times with the rear wheel installed without problem I was pretty surprised that the rear wheel was such a major counterweight. My 'fix' was to place two 50 lb. bags of concrete on the right rear corner of the stand.
This isn't to start a paddock stand thread, just to inform those with the Triumph stand (or a similar design) of this.
Brad
Old 08-29-2007, 06:02 PM   #2 (permalink)
Moderator
Favourite Bike: 04 Daytona 955i
TechmanBD's Avatar
Other Motorcycle: 07 Victory Kingpin
My solution to that, Tie downs from the rafters that go around each side of the handle bars. I jack up a little, then tighten the tie downs.
Live as if you were to die tomorrow. Learn as if you were to live forever. - Gandhi
TechmanBD is offline   Reply With Quote
Old 08-29-2007, 07:06 PM   #3 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
That's how I did it...
Sounds like great minds think alike, techman!!!
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 08-29-2007, 07:22 PM   #4 (permalink)
Moderator
TechmanBD's Avatar
Engineering at its finest. :
Wait, you are an engineer as well, aren't you? I thought I read that once.
Old 08-29-2007, 07:55 PM   #5 (permalink)
fivehundo's Avatar
Sort-of...
I work as an engineer professionally but my degree is in management. I gained a lot of experience as a launch vehicle systems engineer (rocket scientist while in the military and my current employer put me to work as an engineer.
I was thinking about getting a second Bachelors but I'm not sure yet.
Old 08-30-2007, 10:02 AM   #6 (permalink)
Favourite Bike: '02 Daytona 955i CE
CYLax's Avatar
Other Motorcycle: '07 Daytona 675 (track)
Putting a jackstand under the rear shock linkage works too...just support the bike with straps as Techman said...
CYLax is offline   Reply With Quote
Old 08-30-2007, 02:57 PM   #7 (permalink)
fivehundo's Avatar
Or two jackstands under to footpegs...
That works too...
Old 08-30-2007, 03:01 PM   #8 (permalink)
CYLax's Avatar
That works too...
Hmm...handn't thought of that one. No risk of damage to the rearsets?
Old 08-30-2007, 08:09 PM   #9 (permalink)
fivehundo's Avatar
I didn't have any damage when I did it. I did put a couple of rags on the jackstands but it worked out okay...
Old 08-31-2007, 08:58 PM   #10 (permalink)
Favourite Bike: '98 Daytona
Wally's Avatar
Other Motorcycle: '64 T120 in pieces
Same here! Looks about as redneck as it can get, but function is what I was after. To remove your forks put the straps around the top tubes of the frame instead of the handlebars.
Wally is offline   Reply With Quote
Multiple Personalities. CAUTION! welshrob Speed Triple Forum 10 07-19-2007 10:43 AM
A Caution on Seat Installation mecscc Twins Technical Talk 2 08-06-2006 09:01 PM
Self Service - CAUTION - Nerver trust anyone!!!! ken750f Speed Triple Forum 7 08-31-2005 07:41 PM
Best bang for the buck. Caution, it's a rant. b50bsa Sprint Forum 20 08-10-2005 06:19 AM
