| Daytona Deliberations For owners and riders of Daytona 900, 955, 1000 & 1200 |
08-27-2007, 12:16 AM
Site Supporter World SuperBike Favourite Bike: Today - MV Agusta F4 312
Posts: 2,388 Other Motorcycle: 2002 955i Daytona CE Extra Motorcycle: 2009 Tiger 1050
Can Someone Check my work?
Okay, this job has been a little troublesome (to say the least) and I think I've got my engine timed correctly. Can one of you guys verify that I have done this correctly? I just want to double check.
Also, I spun the engine (accidentally) with the camshafts out. Could my engine be off by a revolution? If it is, does that matter at all?
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
08-27-2007, 12:38 AM
I haven't dug into mine yet so I can't tell you for sure, but it looks like typical timing mark nomenclature. Do you have a service manual to refer to? What kind of work were you doing to it?
Love the quote; who was/is Herger the Joyous?
"The older I get, the faster I was".
08-27-2007, 01:35 AM
Site Supporter Nova Favourite Bike: '03 Daytona 955i
The quote is from the movie The 13th Warrior, and pretty accurately expresses the viking opinion of fate.
As long as the crank is at TDC (or, I suppose, BDC) and the camshafts are properly positioned for that crank position, you should be fine.
I won't stop riding because you tell me about someone who died in an accident, just as I won't stop eating because someone died of e.coli.
HiDesert's ride photos
08-27-2007, 02:25 AM
Yeah, I've looked at the manual. I was doing a valve job while I had the bike apart. Two of my valve clearances were out of spec...
The book says I'm good but I wanted to check with all the experts on here.
Yep, hidesert is right.
The book is better than the movie but I like the movie too. It's just too short.
10-07-2007, 11:32 PM
Powerbike Favourite Bike: S1 Lightning
Posts: 388 Other Motorcycle: '96 FXDL Extra Motorcycle: DRZ400S
Let's see; a four-stroke completes one full cycle in 720 degrees, so, if you spun the crank 360 degrees, your compression stroke will now occur where where your exhaust stroke used to occur, or vise versa, right?
Hard to know exactly what people mean by 'the real world'. Whatever it is, this is the primo sports bike for it. Plenty of everything and that triple howl! Sept 03 T.W.O.(Triumph Daytona955i)
10-09-2007, 08:10 PM
See, that's what I was afraid of...
I had to re-time the valves anyway, so does that matter? Is TDC on the compression stroke the same as TDC on the exhuast stroke (so long as I change the valve timing) or is there some other considerations that I haven't thought about?
I'd think TDC would be TDC but maybe not...
10-10-2007, 04:03 AM
Powerbike Favourite Bike: Daytona 955i CE
Can you check it the "old school" way?
Pull a plug and insert a piece of wire. Watch the valves as the piston comes up...if the valves are closed it's on compression stroke. If the exhaust valves are open, it's on exhaust.
The crank doesn't care if it's on compression or exhaust, the valves determine the stroke. But if the crank is one revolution off, will the crank sensor try to fire the plug at TDC exhaust instead of TDC compression?
Wombat wrote:
Don't confuse education with intelligence. There are alot of highly educated idiots out there.
10-10-2007, 04:24 AM
Yeah, if it was a carburaeted engine, this wouldn't be a problem but with all of the sensors and stuff, I'm not sure...
Here is how I got into this mess: I was adjusting my valves and when I went to replace everything, the chain got hung up on one of the teeth of the crank sprocket after I installed the tentioner and it jumped a tooth. I spun it around a few times to see if the timing was off, and it was.
I pulled everything off again and re-timed it. This time it stuck but the fact that I could be off by 1 revolution concerned me. What's the worst that could happen? It will either not run or at the very least, not run well... (right?)
10-10-2007, 12:44 PM
As long as you're SURE it's timed right, you don't have to worry about the pistons banging into the valves. I'm guessing it will either run right or not at all.
10-10-2007, 01:51 PM
Yeah, it turns free without obstruction. The timing appears to be correct but if it's off by 360 deg, I'm not sure if it will run or not...
