Where's the hose? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-26-2007, 02:13 PM   #1 (permalink)
Favourite Bike: 2004 Daytona 955i
Question Where's the hose?
While removing the fuel tank from my 04 Daytona to get at the air filter, I noticed there is no hose connected to the fuel pressure regulator on the side of the tank. The Triumph manual clearly says to remove the hose as one of the steps for removing the tank. I can't find any hose end without a home underneath the tank anywhere, and the bike runs fine.
What's the deal?
oldyeller is offline   Reply With Quote
Old 08-26-2007, 02:39 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
oldyeller, There is no hose on my '04 either...I don't remember 100%, but I don't think the '02 has one either.
Brad
Old 08-26-2007, 02:42 PM   #3 (permalink)
Thanks, Bradtx. I couldn't remember for sure whether it was there the last time I had the tank off or not. Strange, isn't it? Did they decide at some point the fuel pressure regulator was unnecessary?
Old 08-26-2007, 06:00 PM   #4 (permalink)
bradtx's Avatar
oldyeller, My best SWAG is that once the lambda sensor was placed into the system the adjustable FPR wasn't necessary.
Brad
Old 08-26-2007, 06:10 PM   #5 (permalink)
I'll buy that, since I don't even know what a lambda sensor is (sounds vaguely dirty)!
Old 08-26-2007, 08:12 PM   #6 (permalink)
Favourite Bike: Daytona 955i CE
Sprocketjockey's Avatar
Earlier models had a short hose connected that didn't go anywhere. On later models Triumph omitted the hose altogether, but since the regulator didn't change the nipple stayed. The regulator just vents to atmosphere.
Wombat wrote:
Don't confuse education with intelligence. There are alot of highly educated idiots out there.
Sprocketjockey is offline   Reply With Quote
Old 08-26-2007, 08:37 PM   #7 (permalink)
Thanks for the info, Sprocketjockey.
Old 08-26-2007, 09:04 PM   #8 (permalink)
Favourite Bike: '03 Daytona 955i
HiDesert's Avatar
Sure; when in doubt, call it an extra nipple!
I won't stop riding because you tell me about someone who died in an accident, just as I won't stop eating because someone died of e.coli.
HiDesert's ride photos
HiDesert is offline   Reply With Quote
Old 08-27-2007, 12:54 AM   #9 (permalink)
rickster's Avatar
My guess (that word lets me off the hook if I'm wrong) is that the pressure regulator is built into the pump, or that the pump is self regulating. There are no connections on my bike between the fuel rail, etc. and the tank, other than the fuel line. The two nipples serve these functions:
One runs up to the cap and is connected to the air space inside the tank when the cap is closed; thus it's the vent connection. My vent hose had a check valve in it which the dealer removed to no effect.
The other connects to the hole under the cap cavity and drains off any fuel spillage (God forbid that happens!).
"The older I get, the faster I was".
rickster is offline   Reply With Quote
Whats this hose for? stu Sprint Forum 2 08-10-2007 11:57 PM
Hose question BassCat Twins Technical Talk 6 02-01-2007 12:08 PM
What is this hose??? SDFOUR Triumph SuperSports 1 12-30-2006 08:39 PM
cracked hose txsport06 Triumph SuperSports 3 06-15-2006 04:49 PM
HOSE / mystery hose bonnieamer1 Twins Talk 8 09-11-2005 02:04 AM
