Dead 595 Daytona - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearOntario TourismNew BonnevilleHonda Powersports
Old 08-20-2007, 07:29 PM   #1 (permalink)
Newbie
Dead 595 Daytona
P Reg, riding along, engine stopped and wouldn't restart. Took to local motorcycle dealer who tried to access diagnostics - said wouldn't download and give them the information so it must be the ecu - (£1000 please). Anybody else had a similar problem? Will turn over but won't fire and engine management light on. Hope someone has a cheaper answer!!!!
gruff is offline   Reply With Quote
Old 08-20-2007, 08:10 PM   #2 (permalink)
Favourite Bike: 2000 Sprint RS--Beowulf
seumas's Avatar
Other Motorcycle: 1995 Sprint 900
You might try posting this in the Daytona forum. This one's for the older carbed triples.
"We fight not for glory, nor for wealth, nor honor but only and alone
we fight for freedom, which no good man surrenders but with his life."
seumas is online now   Reply With Quote
Old 08-21-2007, 03:10 AM   #3 (permalink)
Favourite Bike: Daytona T595/955
ladyhawk's Avatar
Hey, wait a minute...
Like, Scoob, where am I? I thought this WAS the Daytona forum??
At any rate, I am very sorry to hear of this happening, gruff. I, myself, am of no help to you, but I betcha someone else here will have ideas. Was the "local motorcycle dealer" you went to a Triumph dealer? Geez, you'd think THEY would have a better answer than that...? Don't give up, keep trying...it seems like the T595's have a lot of heart and run well if cared for!
ladyhawk is offline   Reply With Quote
Old 08-21-2007, 10:05 AM   #4 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
gruff, Check the fuses, relays (by swapping) and the earth (ground) block between the gas tank and the ECU. Unless the bike was hit by lightning or there was a sloppy jump start the ECU is pretty sturdy.
Brad
Old 08-21-2007, 01:55 PM   #5 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
Brad
EXTREMELY sturdy.
I've only heard of one on a Daytona going bad...
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 08-21-2007, 07:17 PM   #6 (permalink)
Newbie
Sorry
Thought this was the daytona area.
Thanks for the suggestions - will carry on the investigations - hopefully will find a sign of life!!!
Old 08-21-2007, 10:42 PM   #7 (permalink)
Favourite Bike: BMW K1300S
luiz's Avatar
This is the Daytona area, "Daytona Deliberations"
Most of the post here are from owners of injected 595s and 955is, I dont know why someone said is restricted to carb'd early Daytonas...
Am I right, moderator?
Regarding dead T595, I believe is unlikely you have a dead ECU. Try reading fault codes in with someone else. If codes cannot be read, power supply to the ECU is a good starting point.
LuizFTO
luiz is offline   Reply With Quote
Old 10-23-2007, 12:35 AM   #8 (permalink)
Exclamation Dead 595 Daytona
Gruff,
Check to see if ECU connection is good also check vacuum hoses had a simular problem with my 98 FI 595 turns out ECU connector was loose as well as cracked vacuum hoses. A cheap check....
NoFEAR is offline   Reply With Quote
95 daytona 1200 dead Kingjoey5000 Daytona Deliberations 8 02-12-2008 01:43 AM
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 01:37 AM
backfiring daytona 595 contactkellie Daytona Deliberations 5 10-23-2007 12:01 AM
Buying a 595? BenRoe Daytona Deliberations 5 08-01-2007 03:27 PM
595 purchase???? greenocktriple Speed Triple Forum 0 06-07-2005 11:38 AM
