02 daytona/00RS just died while driving
I was just driving the other day and my bike just died. I pull over and turn the key on and off and everything seems normal except that my fuel pump isnt turning on, so I figure that it is just a bad pump, or a little connection problem. I get home, tear it apart and test the fuel pump and it is still ok. It turns out that the pump wasnt grounding out, I checked the wire and it just goes strait to the ECM. So I just manually ground the pump out and it worked fine but didnt shut off after the 3 seconds once the key is turned on. So I said ok, i will still try and start the thing, and it still wont start, so I go and I check spark, no spark! and I just cant seem to figure out how exactly this is happening, what else could it be besides a bad ECM? I have already checked all of my fuses and they checked out ok. I dont think that this bike has a fuel relay so????I have also checked my grounds, they all seem to be intact. The only reason that I am so hesitant about it being the ECM is because they never go out, I have called a dozen different mechanics and they said they dont know, and that it sounds like a bad ECM but they thought that other things should go bad as well. On top of that, they say that they never go out, only one in a million....so..... I have also thought about, the kickstand switch, the clutch control, and the neutral switch...but I havent checked them, they seem to be alright. I could really use some advice/help...
Thanks,
John
