First, if memory serves, the bulb number for the little bulb is 194. It's available at almost every auto parts store, there are a variety of colors, but make sure that the one you choose doesn't make you a magnet for local law enforcement. I know that in the US, you aren't allowed to run red or blue.
As far as removing those bulbs, pull the upper fairing off, and they are in rubber plugs, they pull out of the headlight assembly, and the bulb pulls out of the rubber bit. At least that's how it's done on '02-'06 models.
