easy question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-12-2007, 01:12 AM   #1 (permalink)
easy question
Can someone tell me the size of the rear wheel nut? i didn't get a owners handbook with mine and i gotta buy a socket so that i can adjust the chain, thanks pete...
peterk is offline   Reply With Quote
Old 08-12-2007, 02:16 AM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Hey Pete,
What year, model, and swingarm type (double or single sided) is this regarding? We can get you that socket size once we know this. Also, if it is a SSSA, then you need not take the axle nut loose to adjust the chain.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 08-12-2007, 02:34 AM   #3 (permalink)
Favourite Bike: 2004 Red Daytona
Other Motorcycle: 1996 Super III Daytona
Extra Motorcycle: 1999 Red Daytona
i agree...what year...and is it a sssa(single sided swing arm) or a dssa( double sided swing arm)? bombfactory is correct in that IF it is a SSSA ...it only needs to have the clamp bolt on the rear of the swing arm loosened. then use the spanner to tighten the chain to specs. otherwise the Double sided swing arm needs both bolts loosened, and the concentric adjuster moved on both sides equally, to tighten to specs.
CHECK OUT MY BLOG...www.triumph-travels.blogspot.com
I've got 2 words for ya.."Shake and Bake"...oh yeah that blew you mind didn't it????.
dano is offline   Reply With Quote
Old 08-12-2007, 10:49 PM   #4 (permalink)
should have thought to put some more details
1998 Daytona 955i SSSA
thanks pete...
Old 08-12-2007, 11:50 PM   #5 (permalink)
DEcosse's Avatar
Then the axle nut is 46mm and you do not loosen it to adjust the chain.
Here's how to adjust the chain: be careful not to overtighten!
Most newbs tend to overtighten SSSA chains - not good!
T'Rat.net BOTM November 2009
Old 08-15-2007, 03:46 AM   #6 (permalink)
Thanks for the info...
Quick, easy question gypsy56 Twins Technical Talk 1 04-08-2007 10:32 PM
Easy timing question kawtoy Classic, Vintage & Veteran 4 06-07-2006 09:11 PM
easy question mrcheese Classic, Vintage & Veteran 11 05-19-2006 09:56 PM
Petcock- easy question MA0458 Twins Talk 2 04-01-2006 03:12 AM
an easy question about mirrors doglanta Maintenance & Workshop Talk 5 06-11-2004 08:09 PM
