02 Daytona Problems with speedo - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-10-2007, 11:40 PM   #1 (permalink)
Favourite Bike: 02 Daytona 955i CE
Other Motorcycle: 1981 Yamaha 650(wife's)
Intermittantly my speedo doesn't work. It reads 0. When it happens it sometimes reads 1 or 2 mph then goes back to 0. Now if I shut it off and re start it sometimes it works. It does this to me two or three times a week. What do you think the problem is? I heard the speedo reads off the front tire. Could it be a sensor starting to fail?
THanks
Andy
awegs955i is offline   Reply With Quote
Old 08-11-2007, 12:45 AM   #2 (permalink)
Favourite Bike: Rocket III Tourer
Low voltage, need new tune, both?
this previous posting about covers it all.
http://www.triumphrat.net/showthread...edometer+error
DaytonaNewbie is offline   Reply With Quote
Old 08-11-2007, 01:04 AM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I had the same problem. Loading a newer tune solved the issue. Search the TRAT database an you will see that this is one of the most discussed issues.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 08-11-2007, 09:30 AM   #4 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Andy, There are two types of speedo failures with the '02> D955is. First is the classic '0 reading' and the second where very low readings are displayed.
The first is caused by a low battery or a poor electrical connection (usually at the battery). Even after rectifying the original problem the speedo will often still misbehave. In this case either the tune boy's speedo diagnostic disable or a Triumph repair tune needs to be loaded.
The second is caused by a front wheel sensor failure (usually after r/r'g the front wheel) and requires a replacement.
Brad
Old 08-16-2007, 10:13 AM   #5 (permalink)
Newbie
I had the same problem with my 2002 model daytona. Checked other forums where low battery voltage was mentioned along with other things. For me it was eventually a new tune of the ECU. It had to be sent to the Triumph factory to get the new tune because the dealer was not able to program that part of the ECU.
Hobie
hobie1 is offline   Reply With Quote
Speedo problems Riderpaul Twins Technical Talk 17 01-26-2008 08:04 AM
HELP speedo problems 00 TT600 mcoop Triumph SuperSports 15 07-24-2007 01:56 AM
955 Speedo Problems justJeff Speed Triple Forum 6 02-19-2007 04:16 AM
...anyone know if this speedo cable is right for my 69 Daytona Lumbee Classic, Vintage & Veteran 2 10-18-2006 11:33 AM
Again, speedo problems. Has anyone had the speedo go out with a jellero Sprint Forum 11 10-18-2005 09:35 PM
