Tuneboy help needed - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-05-2007, 12:59 PM   #1 (permalink)
Ansky's Avatar
Tuneboy help needed
I have downloaded the mm2 map on the laptop.As I try to load it onto the Ecu I get authfail bottom of screen.The key has been loaded, and the cable is properly connected. Any ideas? Thanks
Ansky is offline   Reply With Quote
Old 08-05-2007, 01:29 PM   #2 (permalink)
Make sure the "cable type" is set correctly.
triumphtimes is offline   Reply With Quote
Old 08-05-2007, 01:55 PM   #3 (permalink)
Ansky's Avatar
As in usb?
Old 08-05-2007, 04:46 PM   #4 (permalink)
If you have a USB cable try the USB setting. Seems I read somewhere that there are sometimes problems with that setting, but try it. I has a serial cable that I us a USB adapter and my cable type is set to "cable type 2". It isn't going to hurt anything to try dirrent settings, but if the USB doesn't work try #2
Old 08-05-2007, 07:21 PM   #5 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Sometimes your computer will require you to install two USB devices when you first plug in the Tuneboy cable. If you only installed one, that could be the problem. However, If you have already obtained the ECU# then your USB settings should be correct, as you would have been unable to retrieve the ECU# without the proper settings. I would double check that you have entered the password correctly, and that the tune you are attempting to load is in fact for your engine year/model. Also, make sure the red light on the USB plug is flashing red. If it is not, then you don't have communication between the bike and the computer.
Here is Tuneboy's serial port instructions:
"By default the Serial Port (communications port) is set to COM1. Ensure that the selected port is the port that you are using to connect the cable to the bike. Change this if necessary.
If you have a TuneBoy USB cable that shows up in the serial port list as "USB Serial Port (COMnn)" then you should set the cable type to USB.
If the cable shows up as "TuneBoy Cable(COMnn)" then the cable type should be set to 2.
Serial port 2 is only used when you use the Dynojet Tuning Link software."
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 08-08-2007, 01:18 PM   #6 (permalink)
Other Motorcycle: GSXR 750
Extra Motorcycle: XR 400
You can check with this forum and see if your question has been asked/answered already. If not post it and it should be answered shortly. Lotsa Tuneboy knowledge there and Wayne drops in from time to time.
http://www.t595.net/messageboard/for...ppings/15.aspx
or you can go to Tuneboy site and read the tutorials and FAQ's.
http://www.tuneboy.com.au/Tutorials/Tutorials.html
firemanjim is offline   Reply With Quote
tuneboy cable needed hikinghome Tiger Chat 2 12-06-2007 12:54 PM
Advice needed - fueling/tuneboy issue reid4130 Speed Triple Forum 2 11-17-2007 05:06 PM
Tuneboy needed for wolf pipes? loco Daytona Deliberations 14 01-17-2007 07:58 AM
Tuneboy in the UK fryingtonite Speed Triple Forum 0 06-16-2006 08:38 AM
Tuneboy help needed Seattleducati Sprint Forum 9 05-13-2006 07:20 PM
