2000 Daytona 955 Chain adjustment not working
Hi, I have tried to adjust my chain several times this afternoon and I am having this problem.
I got the back end off the ground and found that as you rotate the rear tire, the chain goes slack and then tight as it rotates?
And I mean pretty tight, to falling of the sprocket loose!
Any clue? I'm lost here, there has never been a problem but I saw the chain looked a little loose and then found this?
Any help would be appreciated.
