I just got a California bike and I'd like to eliminate any future problem areas.
I added the reference to the Idle Air Control Valve (IACV) in the drawing below - is that what it is?
If so then I'd just like to confirm, I'm going to remove everything in this drawing except the IACV and then run three new hoses from the IACV directly to the idle air ports on the cylinder head, correct?
In another thread someone said the hose from the fuel tank gets routed towards the ground, which makes sense, but I'd like to confirm that too.
Thanks!
EVAP System by crossie, on Flickr
Thanks!
