Motorcycle.com
Old 06-26-2007   #1 (permalink)
TrickyVIC
02 Daytona 955i wont start ran fine then went out one morning and it acted like it wanted to turn over.but never did. any idea. Some of my friends say it a relay to my fuel pump or it is my fuel pump.
Old 06-26-2007   #2 (permalink)
charge the batt and then see what happens. More time then not its this.
2002 Daytona
SS brake Lines
1 down in the front 2 up in the rear
Carbon rear hugger
CCC Exhaust
http://i38.photobucket.com/albums/e1...6/DSC00159.jpg
Japawhat02 is offline   Reply With Quote
Old 06-27-2007   #3 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Open the gas tank, try again & report if it's any different!
GSXR 1000 Front End Swap
Old 06-27-2007   #4 (permalink)
TrickyVIC
I put a new batt on and it still will not start. sounds like the fuel pump is working but it sound weak not as loud as it was since i bought it. Maybe it is the spark plugs. what do you think?
Old 06-27-2007   #5 (permalink)
Favorite Bike: 06 D955
Other Motorcycle: several
Extra Motorcycle: yes
I started having this same problem on my 06 the last few weeks. It is intermittent, but very irritating. Turns over but won't start. Acts like it wants to fire but just can't. I have to just keep trying and it eventually fires up, but acts like it is struggling to run until I throttle it. These are the types of problems that could be a real pain if one was on a trip somewhere and this makes me leary to ride the thing to Texas from here. I am beginning to think the RS is more reliable than the new bike.
TT
Note to self: never allow yourself to be goodpastered, lancastered or nyed.
triumphtimes is offline   Reply With Quote
Old 06-27-2007   #6 (permalink)
Has anybody thought of changing the fuel filter? Mine has been having the same trouble. I just picked one up and will have the results this weekend for everyone.
cal-riss is offline   Reply With Quote
Old 06-27-2007   #7 (permalink)
I was over at mt regular mechanics getting tires put on today and he went to take a spin and the bike wouldn't start. I mean just would not fire for about two or three minutes of trying and finally it fired after using the power switch on/off and opening the tank lid. Then it didn't fire hard as it usually does it barely stayed running. I called the dealer from there and told them this is the fifth time in three weeks I've had this happen. The dealer said they have had some problems with the daytonas and the ground. The fix is an extra ground from the head to the grounding block(whatever or wherever that is) to the negative terminal on the battery. Also suggested I don't use the tuneboy as they've had some customers with bad tunes loaded from tuneboy. He also suggested just updating the Triumph tune when I bring it in. Anyone know what or where the grounding block is? And I don't think the tuneboy is the problem, but I will try and reload the tune after I add a second ground.
Old 06-28-2007   #8 (permalink)
You talked to MCC didn't you. They told me the same thing.
" 60% of the time...it works EVERYTIME."
955iLimited is offline   Reply With Quote
Old 06-28-2007   #9 (permalink)
I had a similar problem on my bike, two days after I bought it. It was cranking slowly and almost didn't start. My dealer's mech. found that both cables were loose. The next day I shut it off at an errand and came back 5 min. later and it wouldn't crank at all. A fellow Triumph rider with a new Bonneville was parked next to me, and he fetched a set of cables and got me going (Cheers, Mark!). When I got to my dealer they checked it with the scan tool and it showed a defective battery. With the new battery, so far, so good. It fires after 3-4 cranks, even when hot.
"The older I get, the faster I was".
rickster is offline   Reply With Quote
Old 06-28-2007   #10 (permalink)
Favorite Bike: Daytona 955i CE
Sprocketjockey's Avatar
Dealers hate Tuneboy...it's $$ out of their pocket.
Wombat wrote:
Don't confuse education with intelligence. There are alot of highly educated idiots out there.
Sprocketjockey is offline   Reply With Quote
Bike wouldn't Start %^% googus Sprint Forum 71 02-10-2008 02:59 PM
Help! Bike won't start sagaris Daytona Deliberations 9 09-27-2007 04:47 PM
Bike won't start. wijer409 T3 Sport / Touring Forum 11 05-18-2007 05:16 AM
Bike won't Start HELP! MAC77 Twins Technical Talk 11 04-19-2007 01:27 AM
Bike won't start... Triumph SuperSports 2 02-10-2005 12:18 PM
