AdvanstarMotorcycleShowsSpringfield ArmoryCycleGear.comShopTriumph.comSportbikeTrackGearAnnitori DistributingBikeBanditMotorcycle.com Classifieds!TriumphPerformanceUSAMotorcycle.com
Old 10-26-2004   #1 (permalink)
Favorite Bike: S1 Lightning
Other Motorcycle: '96 FXDL
Extra Motorcycle: DRZ400S
I can put a Thruxton adjustable dogleg style clutch lever by purchacing a '04 Daytona clutch perch. Total cost of $60 US. :-D
Hard to know exactly what people mean by 'the real world'. Whatever it is, this is the primo sports bike for it. Plenty of everything and that triple howl! Sept 03 T.W.O.(Triumph Daytona955i)
02Daytona955i is offline   Reply With Quote
Old 02-03-2005   #2 (permalink)
Was interested in this mod. Do you have specific part numbers and was it an easy DIY project? I called my local dealer and he wasn't sure the Thruxton would work with the daytona perch.
Thanks,
-E
Ericnsh is offline   Reply With Quote
Old 02-03-2005   #3 (permalink)
Thanks,
-E
Old 02-03-2005   #4 (permalink)
It works fine, trust me.............. :-D
Take a peek at the perch on the Thruxton and the one on the '04 Daytona; look the same, don't they? The Thruxton has a mount for the mirror on the clamp part of the perch, but you don't need or want that; you'll be using the clamp off of your old perch.
Don't forget to order the adjuster and the friction spring for the '04 perch as the earlier adjuster is different. Make sure to get the pin the pivot rides on and the bushing too. You'll re-use the nut from your old pivot pin.
Still don't believe me? Look at the clutch on the '05 Speed Triple.
I'd give you the part numbers, but my dealer screwed up and re-ordered a '02 perch first, so the only way I'd be able to give you the correct number is by looking at the computer at the dealer, which your parts guy should be able to do.
Good luck, Ken
Old 02-03-2005   #5 (permalink)
Good luck, Ken
Old 02-03-2005   #6 (permalink)
Thanks for the reply Ken.
So just to summarize i need to order a Thruxton Dogleg Clutch Lever and an 04 Daytona Perch right?
When i called the parts manager he quoted me for the clutch lever and mentioned a few other pieces front whatchamahoosit and another thingamajig. And that was before i inquired about the perch.
I'm not what you'd call familiar with motorcycle parts so it was all greek to me. I also found that Skyking has an adjustable clutch lever for the Daytona but runs about $95 but $60 for this mod sounds better. I just dont' know if this mod is hard to do or not. The Skyking is just a lever change.
-E
Old 02-03-2005   #7 (permalink)
-E
Old 02-03-2005   #8 (permalink)
Unfortunately, the Sky King doesn't dog leg like the Thruxton lever, and it does cost more.
The dog leg lets your index, ring and middle fingers do more work, which makes a huge difference in the feel.
If you can switch to the SK giddyup, you can do this mod, it's real simple.
A set of allen wrenches and a small box wrench for the nut on the pin is all you need.
Old 02-03-2005   #9 (permalink)
Good news and Bad news forresterone Street Triple Forum 23 01-23-2008 03:22 PM
Bad news, good news, and a caution... tba-golfer Twins Technical Talk 5 08-26-2007 10:46 AM
Brits. Good News Bad News. Archimedes Speed Triple Forum 4 08-11-2005 04:52 PM
Good news,bad news...IOM weezer Speed Triple Forum 1 06-02-2005 01:27 AM
Good news and bad news.. Scottius Sprint Forum 3 06-25-2004 01:04 PM
