How to adjust my chain? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.comSportbikeTrackGear
Old 06-13-2007, 05:01 PM   #1 (permalink)
Stupid question but here it goes. I also dont have a owners manual and Im sure it tells in there.
My chain is a bit loose, how do i take the slack out and how tight should it be? The bike is a 01 Daytona 955i.
Thanks
[ This message was edited by: Flat6 on 2007-06-13 16:02 ]
Flat6 is offline   Reply With Quote
Old 06-13-2007, 05:25 PM   #2 (permalink)
With the single sided swingarm, the back axle is a cam. There is a pinch bolt holding everything tight on the back of the swingarm. Get the back wheel off the ground with a stand and open the pinch bolt. There is a sickle shaped tool in the Triumph toolkit that can tighten and relax the chain position. It connects to a notched area of the hub between the sprocket and the swingarm body.
I know that is a little cryptic, but look at it and it will make sense.
Good luck.
ROWYKO!
xactoman is offline   Reply With Quote
Old 06-13-2007, 05:29 PM   #3 (permalink)
Main Motorcycle: 1998 Thubderbird Sport
idahotb's Avatar
Other Motorcycle: 1996 Sprint
Extra Motorcycle: 1997 T595 Daytona
Loosen the pinch bolt on the swing arm (17mm). The use the C- shaped spanner in the tool kit (if you got one) on the eccentric adjuster on the hub. Anti-clockwise tightens it I think. Should be 35-40mm free play at mid chain. Then tighten the pinch bolt to 55 Nm's.
Hope that helps.
Speed is good. It is way better to be shot out of a cannon, than squeezed out of a tube. That is why God made motorcyles.
My album
idahotb is offline   Reply With Quote
Old 06-17-2007, 04:04 PM   #4 (permalink)
Main Motorcycle: 03' Triumph Daytona 955i
Other Motorcycle: GSXR 600 (Track Bike)
Extra Motorcycle: Taking donations...
No need to raise the tire off the ground, really. it's a SSSA, so you can adjust it on the ground. BTW, SSSA chains have WAYYY more slack than a DSSA chain. You have to remember that when you overtighten a SSSA chain, you are actually affecting the entire rear suspension.......
35MM is perfecto!
HTH,
Ski
Track Days at Gateway International Raceway- 2008 Visit WWW.MCRARACING.COM
Looking for a good M/C web forum in St. Louis? WWW.GATEWAYROCKERS.COM
Skiandclimb is offline   Reply With Quote
Old 05-29-2009, 06:26 PM   #5 (permalink)
Main Motorcycle: '04 daytona 955i
is this measurment on the top of the swing arm or the bottom.......
No question is stupid, if you do not understand how it works.....
REDNECK1 is offline   Reply With Quote
Old 05-30-2009, 03:20 AM   #6 (permalink)
Main Motorcycle: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
For the record, if you don't have that special tool from triumph, a few other items will work, in a pinch...
Now, these are certainly not "dealer recommended" procedures, so: "Perform at your own risk!!!"
You can use a center punch and a hammer to tighten it up a little, if you cannot get the wrench in time. Just make sure it is placed evenly and square on the tooth...
...and tap lightly. It doesn't take a lot of force...
I only tell you this because a properly maintained chain is safer then riding with a loose chain because the tool didn't arrive in time. Like any job, it should be performed with the proper tools but if you don't have them, it's okay to "improvise" a little...
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 05-30-2009, 03:52 PM   #7 (permalink)
my goodness!!!!,....that was so simple it hurts!!!! 1 17mm socket, a torque wrench,the tool,......under 5min!! may all maintenance issues be this easy....haha!
Old 02-17-2012, 09:47 PM   #8 (permalink)
Main Motorcycle: 1999 Sprint ST
Other Motorcycle: 1985 Honda Nighthawk 700S
Extra Motorcycle: 88 Ninja 750R cafe racer
Its very easy once u figure it out.
DeusExMaxima is offline   Reply With Quote
Old 02-18-2012, 10:39 PM   #9 (permalink)
Main Motorcycle: 03 Daytona955iSE
Other Motorcycle: rd350lc
Extra Motorcycle: 06 Daytona 1050 SpecProjc
Just thinking,is the axal set at 6o'clock or 12o'clock from the factory?The unenlighted must know this!
alloymotor is online now   Reply With Quote
Old 09-16-2012, 01:09 PM   #10 (permalink)
Main Motorcycle: Triumph Thunderbird
Other Motorcycle: Thunderbird
Extra Motorcycle: Gs650 bobber project
Mine won't turn at all any suggestions
Fizzyhair is offline   Reply With Quote
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 04:30 PM
Help With Chain Adjust WardenRoss Sprint Forum 2 06-26-2007 08:50 AM
ST Chain Adjust TXRyder Sprint Forum 7 03-13-2006 09:05 PM
2.5 Hours to Adjust the Chain Nelson955 Sprint Forum 25 11-23-2005 04:20 PM
HELP! CHain adjust on 02 ST kelticwolv Sprint Forum 2 04-08-2005 11:52 PM
