The light you speak of--if it's illuminating the engine symbol--is a "check engine light" or EMS light (Engine Management System.) To put it in simple terms, your computer control system is picking up an incorrect reading from one or more of the many sensors/wires throughout the motorcycle. Sometimes with enough investigation you could figure out what the problem is yourself, but often times you need to have a mechanic bring up the error code which is stored in the bikes computer. From there the mechanic can figure out exactly what sensor(s)/wire(s) the error(s) is/are coming from.
Just based off what you said about having a Speedo issue, that could very well be what is setting off the EMS light. If the speedo plug has a bad connection, or if there is a short somewhere within the speedo's wiring, the EMS light will come on.
For your information, if you were to find and correct what was causing the EMS light, the light should go off after 3 heat cycles--which is running the bike until running temp is achieved, allowing the bike cool off, and then repeating this 2 more times. Note to others: I don't know the exact time/temps for a "cycle" and don't have time at the moment to search the forums for such info, so that exact info would be nice. Hope that helps. P.S. Welcome!
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
