What does your temp gauge read when it's blowing coolant out of the overflow tube? When you refill everything, are you filling the radiator, or just the resevoir? When you're refilling the radiator, make sure the bike is level, and strip off both the side panels. On the right side of the radiator, at the top, there is a bolt, you can take that out and it helps bleed the air out of the system. Make sure the bike is on some kind of center stand when you're doing this. It won't work right otherwise.
