Overfilled oil !! - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports SportbikeTrackGearMotorcycle.com
Old 05-01-2007, 04:21 AM   #1 (permalink)
Maybe it's me being my usual paranoid self, but..... checked the oil level yesterday and noticed that it was overfilled by about an inch on the dipstick!! (about 3/4 of a litre?!). I must have been in another world when I refilled it after changing the alternator cover a month or so ago. Bike has run perfectly since then though, no leaks, no sign of blown seal etc... obviously I have drained off the oil to the acceptable level now.
All seems well, but just wondering what the chances are that I have actually done some damage. Anyone had experience of overfilling? Are the triple engines okay with this?
Akerman is offline   Reply With Quote
Old 05-01-2007, 07:47 AM   #2 (permalink)
Favourite Bike: 2007 Thruxton Bonneville
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
Only possible problem I can think of running a 955 with too much oil is stressing the motor (shifting extra oil round system) or blowing the gearbox oil seal. The one behind the front sprocket. I'd get a tube and a syringe and take it out if I were you just to be safe.
Nickwiz is offline   Reply With Quote
Old 05-01-2007, 10:11 AM   #3 (permalink)
Yep, I've taken out the excess and it is running fine to be honest. No signs of a leak at the gearbox, although I'm checking it every journey to make sure.
Fingers crossed
Old 05-02-2007, 11:38 PM   #4 (permalink)
If you overfilled it a bit, you could pressurize the crankcase and ruin some seals, or you could possibly pump some oil up into the airbox which would then run into the intakes and burn off. You'would see some pretty blue smoke in this case :-D .
If you REALLY overfill it, same as above with the exeption that you could get sooo much oil up there, you could hydrolock the motor. You would know it if this happened :hammer: .
If nothings amiss or leaking, you did no damage...relax.
Cheers, Lee S.
Keeper of the Schwartz
lee955i is offline   Reply With Quote
Old 05-03-2007, 08:44 AM   #5 (permalink)
Yep, I'm going to put it down to experience and be thankful no damage was done (hopefully !!). Been running it a week now after gettin the levels right and it seems fine.... :upthumb:
Old 05-03-2007, 02:24 PM   #6 (permalink)
Favourite Bike: 02 Daytona 955i CE
Other Motorcycle: 1981 Yamaha 650(wife's)
How many quarts of oil do our bikes take? I just got mine and didnt get an owners manual. I'm about to change it.
Thanks,
Andy
awegs955i is offline   Reply With Quote
Old 05-03-2007, 04:53 PM   #7 (permalink)
Favourite Bike: Triumph Sprint ST
Other Motorcycle: Suzuki DRZ400E
3litres (2.7quarts) oil change only.
3.2litres (2.9quarts) oil+filter.
DaytonaDave is offline   Reply With Quote
Old 05-04-2007, 11:50 AM   #8 (permalink)
Favourite Bike: Today - MV Agusta F4 312
fivehundo's Avatar
Other Motorcycle: 2002 955i Daytona CE
Extra Motorcycle: 2009 Tiger 1050
I just did the same thing on my Husky and blew the oil seal...
Lame!
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
fivehundo is offline   Reply With Quote
Old 05-23-2007, 02:45 PM   #9 (permalink)
Favourite Bike: S1 Lightning
Other Motorcycle: '96 FXDL
Extra Motorcycle: DRZ400S
Thought a liter was more than a quart?
3.78 liters = gallon = 4 quarts
Hard to know exactly what people mean by 'the real world'. Whatever it is, this is the primo sports bike for it. Plenty of everything and that triple howl! Sept 03 T.W.O.(Triumph Daytona955i)
02Daytona955i is offline   Reply With Quote
Uglyed my oil fill cap getting it off. How about oil temp gauge? mlatrella Twins Technical Talk 14 10-21-2007 07:18 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 04:09 PM
TT600 Oil overfilled - consequences Zed Triumph SuperSports 4 03-23-2007 05:26 AM
Overfilled Brake Reservoir CTF Twins Talk 3 01-26-2006 07:57 PM
custom oil tank top end oil feed Classic, Vintage & Veteran 0 05-07-2005 06:22 AM
