Handlebar lock/Park light functionality not working - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-01-2007, 12:59 AM   #1 (permalink)
I've recently laid my hands on a 99 Daytona thats in very good shape with a couple minor exceptions. The park functionality and basically anything left of the start and off positions of the key don't work. The handlebars are all the way turned to the left and I can see that they're touching the stops yet the key won't turn any further left. I've tried every gyration of wiggling, twisting, pushing down and nothing.
Has anyone else experienced this? Its past being tight, it just won't budge...and I'm not interested in twisting off the key!!!
99Torque is offline   Reply With Quote
Old 05-01-2007, 04:01 AM   #2 (permalink)
DEcosse's Avatar
In order for the key to turn anti-clockwise, the first position would be the steering lock - when that operates, a pin in the ignition switch projects from the switch & locates in a hole in a boss on the frame steering head (rotate the bars to the right & you will see the receiving hole)
If you are pushing bars hard left against the stop, it may that you are going too far and the pin is actually past the point of engagement in the hole. There is a 'sweet spot' you need to hit just right.
Try turningbars completely to left, then try to turn the key anti-clockwise & while sustaining pressure on the key, slowly move the bars to the right & see if the key will then turn & the lock pin engage.
Once you get to lock position there should be nothing stopping the key then turning to 'park'
Good luck!!!
T'Rat.net BOTM November 2009
Old 05-01-2007, 10:19 AM   #3 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
99Torque, Try this. Switch to OFF, push down on the key and release, then turn to lock.
Brad
Old 05-01-2007, 11:38 AM   #4 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
Agreed with both comments. Mine does not lock when all the way to the stop. I do have to gently push the key down to get it there.
Brooksie is offline   Reply With Quote
Old 05-01-2007, 11:59 AM   #5 (permalink)
DEcosse's Avatar
Sorry - forgot to mention pushing down on the key but it does have that instruction right on the top of ignition! Important detail of the instruction though.
Old 05-01-2007, 12:23 PM   #6 (permalink)
Thanks, I'll have a go tonight, I'm used to the lock position being full left, once I've had a look at the hole where the locking pin goes it shouldn't be a problem.
Old 05-02-2007, 12:29 PM   #7 (permalink)
Right on fellas, Bradtx, that was the solution had to push down and let it back up, then turn to the left.
Works perfectly now...umm...operator error! Thanks.
TT600 won't switch to steering lock / parking light xmmotorsports Triumph SuperSports 8 07-16-2007 08:58 PM
Clock Light Working intermittedly brianre Tiger Workshop (archive) 2 12-08-2006 06:18 AM
running light not working Howlin_955i Daytona Deliberations 2 08-26-2006 10:07 PM
Engine managment light is on after working on the bike AndyS4 Triumph SuperSports 6 08-04-2006 10:18 AM
00 St oil light not working KevinH Sprint Forum 0 04-27-2006 06:02 PM
