Speedometer - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-24-2007, 12:12 AM   #1 (permalink)
kfamsan
My speedometer has just wet crazy on me this weekend. The max speed it reads is 25 when I know i'm well over 80mph. Do anyone know how to fix this or should I go to the dealer first. I'm hoping to find a quick fix, that I can do myself.
Old 04-24-2007, 12:49 AM   #2 (permalink)
Favourite Bike: 2004 Red Daytona
Other Motorcycle: 1996 Super III Daytona
Extra Motorcycle: 1999 Red Daytona
go to the dealer and ask for a updated tune.....there is a new tune that solves that problem...tell them whats up and they should fix ya up...
CHECK OUT MY BLOG...www.triumph-travels.blogspot.com
I've got 2 words for ya.."Shake and Bake"...oh yeah that blew you mind didn't it????.
dano is offline   Reply With Quote
Old 05-08-2007, 04:31 PM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I believe your speedo drive has gone belly up. The Triumph speedo drives (the hub that is located on the left side of the front wheel) has a magnetic ring inside which is what gives you your rotation reading. The magnets eventually brake or crumble, and sometimes become demagnetized after time. It's a pretty common problem. For some reason you cannot buy the magnetic ring separate from the speedo drive. A new drive will cost you $169 so they aren't cheap! If you find a used one, make sure that it works and that the magnetic ring is intact. I have PM'd you regarding this thread.
[ This message was edited by: BombFactory on 2007-05-08 14:43 ]
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 05-09-2007, 10:30 AM   #4 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
kfamsan, I agree with BF. Had the front wheel been removed recently? The '02 D955i needed a new sensor after a front tire replacement. It too was reading 'partial speed'.
Dano, When I had the 10181 TOR tune installed on the '04 D955i we found a 10152 OEM tune, rather than the 10128 tune on the ECU's label. We think that this is the tune that writes out the self diagnostic that caused zero MPH displays.
Brad
Old 05-09-2007, 03:34 PM   #5 (permalink)
Make sure your battery is fully charged and the battery connections are tight. If it doesn't have enough juice, the first thing to start acting wacky is the speedo...
dml955i is offline   Reply With Quote
Speedometer is off GJJ Sprint Forum 18 08-13-2008 02:11 PM
Speedometer hobowillie Daytona Deliberations 14 07-04-2007 11:09 PM
SPEEDOMETER HELP McCoy Gear & Gadgets 3 05-01-2007 06:42 PM
Speedometer JMV2006 Twins Technical Talk 1 07-28-2006 09:27 PM
speedometer ronniena Sprint Forum 7 03-24-2006 09:12 AM
