BikeBanditTrident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 03-27-2007   #1 (permalink)
Larson955i
I think I have oil in my airbox from a small tip over... I understand I may need to clean it out so... Where the hell is it? How do I get to it? Any cleaning tips?
Thanks
Sorry for stupid question.... Newbie here...
Old 03-27-2007   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Under the gas tank
Remove seat(s) &/or cowel, remove tail section, remove front tank cover; disconnect fuel lines & electrical connectors (including the low level sender on the bottom rear left side) then remove the tank bolts front & rear & remove.
Now you can access the airbox;
Disconnect the hoses from the rear under-side & be sure to make note of which goes where
Loosen the the three boot clamps & pull off the airbox;
Then split the airbox by removing the bolts holding halves together.
GSXR 1000 Front End Swap
Old 03-28-2007   #3 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
Great help! Good luck with the clean up.
Brooksie is offline   Reply With Quote
Old 03-28-2007   #4 (permalink)
Larson955i
Thanks for the help...I try it tomorrow and let you all know how it goes.
Location? STLBB Twins Talk 7 12-29-2007 06:13 PM
Air injection location ? 2Marks Twins Technical Talk 7 07-08-2007 04:29 AM
location of new Tigers HGaither Tiger Chat 8 02-06-2007 09:47 PM
starter location? dacroce Speed Triple Forum 1 11-25-2006 04:37 PM
Ignition Switch Location Raven Twins Technical Talk 3 07-14-2006 08:02 PM
