Old 04-25-2007   #31 (permalink)
Bomboderator
Favorite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Other Motorcycle: '00 TT600/S4 Combo
Thanks,
The headlights pictured are actually stock Speed Four headlights and mount--although they are the same as 02-04 Speed Triples. I got them from a TRat member. I decided to go with the stock setup because it enables me to use the stock-type speedometer mount, while the aftermarket setup would require a separate bracket for the speedo to mount to.
If you are planning on using the Daytona clipons and a S3/S4 headlight assembly, you will probably run into the same problem that I am--that is the master cylinder and clutch assembly run into the speedo. I can't say that this will be a problem with Daytona clipons, as I am using GSXR's; although the masters are the same and the clutch assemblies are very similar.
The aftermarket headlights I was going to use are located here: Aftermarket Headlights
You can't beat the price either!
[ This message was edited by: BombFactory on 2007-04-25 21:54 ]
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
BombFactory is offline   Reply With Quote
Old 04-25-2007   #32 (permalink)
Bomboderator
As for the exhaust, I totally agree that the stock muffler is out of place--and dang heavy to boot! :razz: I would love to put an undertail system on it, but I don't have the funds for such an expensive endeavor. The next alternative would be a high-mount system. I really don't know how many are out there, but I can see a few brands looking at the "member's motorcycle pics" threads. If I can't find a good 02+ Daytona exhaust thread maybe I'll try and get one started?
Old 04-26-2007   #33 (permalink)
hey man don't know if you remember but we chatted a bit via email randomly [about some parts] before you bought the bike - i was the other guy that was thinking about buying it! you got a SCORE!!! i'm stoked that it worked out for you - that the bike was solid and no dmv hassles, etc.
of course i'm also kinda p!ssed, but i'll get over it! ;-)
it looks killer, as for headlights, i'm glad you didn't use the aztec8's - there a total waste of $. i have a set on my daytona / s3 conversion and i've been really disappointed with them - very low quality all the way around [which is very hard to tell from his pictures]. anyway..
i also have to chime in on pipes: i know this is moto blasphemy, but CF is just a BAD material to use for a pipe - it's fragile, and doesn't like heat or elements. get ti or stainless. i had a high mount factory race pipe on my D and it was SO raspy and loud - awful sounding. i have a cheap aluminum leo on there now and it's much much better sounding. fwiw the tri carbon pipes are just a CF wrapper over stainless. is that 'genuine faux' ? =)
i really like the remus pipes - their high mount ti pipe is really lovely.
ask me about rebuilding / repacking the stock [non-rebuildable] pipe sometime [grumble.. grumble..]
anyway good luck + keep us posted. im in SF - nice to see more BA folks out there. later!
jim
[ This message was edited by: thejimrose on 2007-04-26 19:28 ]
thejimrose is offline   Reply With Quote
Old 04-27-2007   #34 (permalink)
justin - got your pm but cant pm back yet - stupid TR 10 post minimum rule. ok.. ok.. i suppose i COULD be a more active member. too many forums, too little time.
ping me at thejimrose @ gmail.com
Old 04-27-2007   #35 (permalink)
Bomboderator
Thanks for the reply Jim--email has been sent.
I just got the headlights installed after painting them and they look great! I went with black base coat and an eggshell clear coat--a little flatter than semi-gloss. Painting chrome is always a *****-shoot, as even when you use proper adhesion primer and sealer, as I did, you are still running the risk of getting rock chips much easier than if you were painting bare metal.
Today (Friday 4/27) is the big day. I am going to ride the Tritona to work! I spent the evening replacing the front wheel grease seals, installing the speedo drive, installing the headlights, and doing some other general things in order to go down the road. I'm a little nervous, but it has nothing to do with safety. There's nothing like getting a project back on the road for the first time in years. :-D
Old 04-30-2007   #36 (permalink)
good luck! hope nothing falls off.. =)
a tip on paining chrome - i've used rattle-can plasti-dip before on grill trim to dechrome. it shoots a plastic coating not paint, but looks great and holds up much better than my 2nd fave; wurth satin black trim paint. especially on a part that gets lots of road debris.
cheers
jim
Old 05-09-2007   #37 (permalink)
Bomboderator
Jim, thanks for the "good luck" and the paint suggestion. I've never heard of using the plasti-dip--I'll have to try that on something. Wurth makes some great spray bomb paints and coating!
It's been a while since I posted an update. I did end up riding the bike to work. It is a great machine!!! I had no problems whatsoever. I'm going to take it easy on the engine for a few miles since it hasn't ran in a long time.
The rear tire that was on the bike is a brand new (4 years old brand new) Metzeler M1. It is still plenty alive, so I bought a M1 front tire to match. I'll take care of that soon.
The clipon clearance situation had been bugging the heck out of me. I thought I would simply cut and move the speedo mounting bracket forward, but it turns out the piece is aluminum. That presents a problem because my buddies TIG welder is in the shop for repairs. I thought about going with a pre 02 Speed Triple headlight bracket which doesn't have the speedo mount. If I did that I could build a bracket that mounts the speedo to the top triple clamp. That would work, but it took me long enough to find the 02+ headlight bracket, so money and time were against me.
I ended up getting a great deal on a set of risers and LSL bar which solves all of the clearance problems--but at the same time creates some new issues. I wanted to flip the bars so that they are lower, but the GSXR preload/rebound adjustment nuts are too high to do so. I ended up mounting the bar in the standard position.
The problems that I now have are that the Daytona clutch cable is too short and the braided stainless brake lines are also too short. If anyone is interested in the brake lines I'll be putting them on the classifieds soon.
So here are the pictures of the bike with the painted headlights and handlebar setup.
Old 05-09-2007   #38 (permalink)
That looks awesome. You've really done alot of work. About the bars, did you think about motorcross style? Like fatbars or something. I really dig the looks of it. Opinions are like well you know what but to me it would even cooler with no front fender and no speedo. I've seen speedos that are tiny and you can mount on the front wheel. Chopper places sell them. I guess they were a 70's thing. Looks great man.
rotten03 is offline   Reply With Quote
Old 05-11-2007   #39 (permalink)
Bomboderator
Rotten3,
Thanks a lot for the complement and opinion. Good mature opinions are always appreciated! I'm afraid I cannot go with flatter bars, as the GSXR preload/rebound adjustment nuts/screws are a lot taller than, let's say, a stock Daytona's. If I went with a flatter bar, it would hit the adjustments. I can't move the risers further back to solve this problem, because I won't get a good turning radius before the bars/controls hit the tank. I too like the no front fender--or a small fender--look, but I'm not too keen on debris hitting the headlights, radiator, tank, me, etc.
On that note, I was looking at my buddies '06 GSXR 600 today which has a very small from fender--like D'Ecosse's. I did some measuring using the only tool I had (my hand) and I am starting to think that I might be able to somehow fit one on the Speedtona; I'll have to get some solid measurements on the fender.
As for now, I'm waiting on some mirror mount clutch/master clamps to arrive, and for a mirror deal to be finalized. I'm going to go out now and get the headlights wired and then get an order for longer brake lines submitted.
Old 06-11-2007   #40 (permalink)
Bomboderator
Well, it seems that I haven't updated this thread in ages! I've been busy with work and have been piecing together all the loose ends for the bike. So the motorcycle is now officially a Speedtona! I have finished all but a few mechanical and cosmetic touches, and have been riding the heck out of the bike the last three days. It is 100% street legal and I obtained a temporary moving permit from the DMV. All that is left to do is to ride over to the DMV and have someone do the final inspection of the bike so I can get the plate and tags.
I ended up purchasing LSL Fatbar risers and handlebar from a TRat member. After installing the setup I found that the bar had been trimmed off too much and because I'm not running bar end mirrors there was nothing to make up the space. I purchased a new LSL Fatbar and installed that. I think I will end up cutting about .25 inch of the ends, but I'm going to wait and make sure that will work before doing so.
The bought a cherry set of '06 Speed Triple mirrors off a TheS3.com member which look really bitchin'.
Due to the fact that I switched from clipons to the bar, the old Galfer Braided SS brake lines were too short. I put in a custom order through Cyclebrakes.com which fit perfectly. The tech that took my order was Melissa who was extremely knowledgeable and helpful. I highly recommend this business if you need any brake parts.
I picked up two sets of tail fairings from TRat members which I made a perfect set out of. I also scored the carbon fiber inlays--dang hard to find used!
So now for the story on how she rides... I cannot believe this thing! It smooths over rough terrain like a Cadillac, yet is easier to throw around than my TT600! I don't really understand why, but I feel much more comfortable and safer on the Speedtona than the TT600. The front brakes are outright ridiculous. I think if I had to I could get the thing up on just the front wheel using my pinkie! And talk about power! I went to pass a car on El Camino and grabbed a little to much throttle in first gear. The front end came off the ground by about 3 feet. That surprised the heck out of me, and probably the woman in the car I was passing!
When I first took the bike out after installing the handlebar, I couldn't’t help but laugh hysterically when I pulled out of the driveway; it felt as if I had ape-hangers on the bike! I said to myself that this was screwed up and there'd be no way I could ride this thing with bars. But after three days of riding I really like the bars. The riding position is extremely relaxed which makes the ride that much more enjoyable. I find that I can counter-steer a lot easier with the bar than the clipons, which also gives me a greater amount of feedback from the front end.
I wonder if this is normal--or maybe I should be put in a loony bin--but I can't get the grin off my face when I'm cruising and look down at the duel headlights. It's just something about the whole look and feel of the bike that is just amazing. And the compliments from fellow riders began from the get-go. Tonight I rode over to a restaurant on the coast where a friend works. When I pulled up there was a 03ish Ducati 999 that just pulled in. The man and woman got off the bike and both looked at each other and said, "Wow, that's a nice bike!" This leads me to a comical story.
I went to the bar where my friend got me an English Breakfast tea with cream (it was cold and I like tea
:razz: ) So I'm sitting there sipping on a British drink with my Triumph parked outside, and I look over to the two Ducati riders and there they are sipping on glasses of wine over a pasta dinner! HaHa! Stereotypes all the way around!
So that's about all I have time to type for now. I'm planning on pulling the front wheel tomorrow and getting my new front tire mounted. Thanks again for all who have contributed to the ongoing project. This is a great gang of motorcycle enthusiasts and friends! Here are the current pictures:
Just bought a 2002 Triumph Daytona CE 955i stephenjpauls Daytona Deliberations 4 05-04-2007 04:10 PM
Dry weight and value of 2002 Daytona 955i Anniversary jh225 Daytona Deliberations 4 08-15-2006 10:31 AM
spark plug for 2002 Daytona 955i nyctester Daytona Deliberations 1 06-12-2006 09:06 PM
It's ALIVE!! Tank project begins to breath.. 6449 Club Cafe 18 05-16-2006 07:24 AM
2002 Daytona 955i aftermarket exhaust markII Daytona Deliberations 9 07-06-2005 01:15 AM
