I do more of a chain alignment than wheel alignment. Using a piece of the aforementioned aluminum extrusion, I lay it up against the tire and right on top of the chain, shoving it up as far as I can toward the C/S sprocket. Adjust the wheel so the chain is parallel with the aluminum piece. If the countershaft and the swingarm pivot are parallel, which I assume they are, the wheel will be aligned. The chain will run quieter and the sprockets will last longer too.
Steve
I had the right to remain silent, just not the ability.
