Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
BikeBandit
Old 03-03-2007   #1 (permalink)
ozark
....but I am somewhat unfamiliar with them. Currently I have a Bandit which I will be keeping but trading in another bike to get this little gem I found calling my name.
Anyway, The guy wants $6500 for it and it appears to be bone stock and in very good shape with only 6400 miles. What else should I look for? Are there any recalls or major issues that I need to know about? What is the maintenance like on it? I don't like doing valve adjustments but I may have to since there isn't a mechanic or dealer within 50 miles of NW Arkansas.
The reason I am considering the Daytona is, well, I once rode a speed triple on a test ride and that motor lives in my dreams. The Bandit is a screamer but I'm really in love with what I have read about the Daytona and it just speaks to me.
What say you?
Old 03-03-2007   #2 (permalink)
Favorite Bike: 2006 Triumph 955i Daytona
Other Motorcycle: BMW R1150RT (Biarritz Blu
Extra Motorcycle: 1996 Laverda 668 Formula
If it speaks to you, answer it.
My '06 whispers to me from the garage and then howls when I ride it.
There are few bikes with this much character available. It's well priced at $6500 and low mileage.
You can do a lot yourself on these bikes but unless you've adjusted shimmed valves before, I'd have a Triumph shop do it especially at 12K.
I bet the Bandit gets less of an outing when you have the Daytona.
Linz :-D
Linz is offline   Reply With Quote
Old 03-03-2007   #3 (permalink)
Favorite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51, sometimes
ozark, All I can say is I've not regretted getting mine.
There really aren't any mechanical issues that weren't addressed by '04, much earlier actually. Well, maybe one...the front brake pistons sometimes stick causing excessive lever travel. On the two D955is here, we just extend the pistons and clean with a tooth brush and brake cleaner while changing the oil (changed at 3K mis., manual says 6K). Just a 15 minute task and easy enough to live with.
If you get it, I suggest going over the battery connections (FI engines like good current) and setting the rebound and dampening to 'N' for baselining...besides, you're gonna want to fiddle with it anyway.
Let us know.
Brad
Old 03-03-2007   #4 (permalink)
Favorite Bike: 06 D955
Other Motorcycle: several
Ozark,
I'll third the motion. I wanted a Daytona when I bought my RS back in 01, but couldn't afford it then. I finally bought an 06 D955 last October and with winter I've managed to put on 4300 miles. In that time I absolutely love the bike, truly awesome. The only problem I have is being 6'1" and long legged, the rearsets are set quite high compared to what I am used to. On rides, after a couple hundred miles my knees and hips cramp a bit, but that could be because I'm old. Buy it if you crave it. There will be no regrets.
Note to self: never allow yourself to be goodpastered, lancastered or nyed by a bad dealer or mechanic.
triumphtimes is offline   Reply With Quote
Old 03-03-2007   #5 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
Best bike I've ever owned and that motor is a joy! I shy away from the valve adjustments, but there is little else the bike will ever need. Weighs less than my Bonnie and has over twice the power. I put Heli risers, tall shield, Triumph stainless pipe and set it up to accomodate soft luggage. Great for scratching or touring!
Brooksie is offline   Reply With Quote
Old 03-03-2007   #6 (permalink)
ozark
Ok- I am going to see about this Bike ASAP! I may even sell the Bandit if I find myself riding Daytona more.
keep the commentary going....don't be afraid to tell me if you have had a bad experience with yours. I am pretty much sold anyway!!
Old 03-03-2007   #7 (permalink)
you probably wont get too many bad things...from us because.....there arnt many. Yes its not going to have the outright speed of Jap bikes but, they dont have the bottom end like we do. But if that mattered you would prolly be lookin at japs anyways. Other than the brakes that brad mentioned, i have no complaints about this fine machine.
BUY IT NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :hammer: :hammer: :-D
[ This message was edited by: Japawhat02 on 2007-03-03 14:41 ]
2002 Daytona
SS brake Lines
1 down in the front 2 up in the rear
Carbon rear hugger
CCC Exhaust
http://i38.photobucket.com/albums/e1...6/DSC00159.jpg
Japawhat02 is offline   Reply With Quote
Old 03-03-2007   #8 (permalink)
Favorite Bike: 04 Daytona 955i SE
stealthy1's Avatar
Other Motorcycle: suzuki gsxr600
Extra Motorcycle: Yamaha yzf600r
Haven't had any problems with my 04 except a couple of slips out of gear (EDIT: FALSE neutrals rather than popping out of gear), but that was my fault for getting the wrong oil. Changed it to the right juice, and not a problem since. You'll love it .
[ This message was edited by: stealthy1 on 2007-03-03 15:28 ]
stealthy1 is offline   Reply With Quote
Old 03-03-2007   #9 (permalink)
Great all round bike. You'll love it!
Richard is offline   Reply With Quote
Old 03-03-2007   #10 (permalink)
ozark
I can't believe I am asking this question but...lol....
what oil do you use? More specifically, what weight?
Seriously, the reason I ask is that I have noticed a clear difference in running the recommended weight oil in my Bandit and using something different.
2004 955I Manual Research Rat Daytona Deliberations 7 02-02-2008 03:47 PM
Used 2004 955i-Maintenence Reco Research Rat Daytona Deliberations 6 01-10-2008 12:28 AM
2004 Daytona 955i Rear Wheel Smittypro Daytona Deliberations 3 12-05-2007 12:39 AM
2004 Daytona 955i, CHEAP! $6000 Smartdrug Daytona Deliberations 4 06-15-2007 11:24 AM
