On 2006-12-09 21:04, buggyto wrote:
.... For the calibration I plan to put the target on a disc with a slot and move the sensor up or down ....
Not sure if I'm mis-understanding you or you're mis-understanding how it works:
The effective diameter of the
sensor/trigger is inconsequential - it will give 'x' number of counts per wheel rotation depending on how many trigger magnets you use - doesn't matter where they are located on the wheel or any part of the rotating assembly. The effect of the
wheel diameter however will affect the net calibration on the speedo itself. You cannot compensate for this difference by moving the sensor/trigger - the number of counts per revolution will remain the same. That's why you use the Yellowbox, to give you a % change that is not achived by a whole number count of trigger magnets (i.e. - if you used 4 magnets & were 20% slow, you would add one more magnet & be correct; however if you were something like 8% or 13% or 24% fast or slow, only way to compensate is to have the yellowbox adjust for it.)
[ This message was edited by: DEcosse on 2006-12-10 00:46 ]
