Here's a link to the 2002 Speed 3 you can download. The 2002 Speed 3 is in the Daytona shop manual because they share the frame and running gear. The engine however is the same as a 2002 RS so the wiring diagram should be the same for the speed 3 or the 02 RS.
There is also the shop manual for a 2001 Daytona/Speed 3 so you can compare the differences.
2002 Speed 3
Warning! The 2001 Daytona/Speed 3 manual is 73mb in size! At 56k modem speed that is OVER 3 Hours to download!
The other one is about an hour. (At full 56k speed)
You will need Acrobat Reader to view the files. I hope you're not using dial up! :-D
[ This message was edited by: Stlakid on 2006-11-24 20:07 ]
