I don't think I'd be messing with the oil level much on a machine that has the power and capabilities of a daytona. Seriously, if you can't adjust it for the road from the settings that are given spend the money for some stiffer springs at first or get a different front end. On older bikes where the front ends are inadequate to begin with tricks to stiffen the action of the forks are sometimes easy to get away with, but I'd sure hate to be into a corner at a good speed and have something go really wrong because of cheap fix. Suspension is to important and critical to mess with without expert advice. I ride my RS year round and notice in the dead of winter when it is cold out the front end does not respond well at all on bumps at certain times, not all the time, but the right bump at the right time has sent me into horrible tank slappers twice. I attribute this to the oil in the forks thickening due to the extreme cold and not being able to allow the forks to do the job it's suppose to. I'm pretty careful in the winter now after two 80 mph severe slappers. I may be wrong, but I'd also hate to hear of someone getting hurt because they messed with their suspension other than the settings provided.
Note to self: never allow yourself to be goodpastered, lancastered or nyed.
