| Daytona Deliberations For owners and riders of Daytona 900, 955, 1000 & 1200 |
09-19-2006, 08:43 AM
Don't have a Triumph dealer near me.
What non-OEM oil filter can I use on my 98 Daytona 955i?
Need a part number/manufaturer, so I can pick it up soon!
[ This message was edited by: RobGoBlue on 2006-09-19 07:03 ]
09-19-2006, 12:38 PM
Cross reference for Triumph oil filter:
Purolator - ML16819 or L14622
Wix - 51358 or 51365
Amsoil - SMF 103
Hastings - LF113
Motorcraft - FL816
AC Delco - PF1237
Bosch - 3323 (long) or 3320 (standard)
K&N 191
From Honda oil filter alternatives:
All these filters have 20 x 1.5 mm threads, 2.3" gasket dia. , approximately 2 3/4" O.D., a bypass valve of 8 to 14 p.s.i., and anti-drain back valves.
3.5" long filters -
Mobil 1 M1-110
Bosch 3323
Purolator L14610
NAPA Gold 1356
Carquest 85356
Wix 51356
Deutsch D-370
AC Delco PF-2057
Motorcraft FL-821
STP S-02867
Penske 7317
Walmart Supertech ST 7317
2.5" long filters -
Bosch 3300
NAPA Gold 1356 or NAPA Gold 1358 (motorcycle specific filter)
Purolator L14612
Purolator ML-16817
AC Delco PF1237 or AC Delco PF2135 (motorcycle specific filter)
STP S-02876
Fram PH6607 or Fram PH6617A (motorcycle specific filter)
Walmart Supertech ST 6607
K & N KN-191 (motorcycle specific filter)
Honda 15410 (motorcycle specific filter)
Reinstated
09-19-2006, 12:44 PM
Site Supporter World SuperBike Favourite Bike: Today - MV Agusta F4 312
Posts: 2,388 Other Motorcycle: 2002 955i Daytona CE Extra Motorcycle: 2009 Tiger 1050
This is a really good reference!!!
Thanks Devious!!! :upthumb:
"The Father wove the skein of your life a long time ago. Go and hide in a hole if you wish, but you won't live one instant longer. Your fate is fixed. Fear profits a man nothing." Herger the Joyous
10-04-2006, 03:09 PM
SuperBike Favourite Bike: 2002 RS
Posts: 1,533 Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
The best oil filter available is the Purlator Pure-One Line part #14610 (3/4" longer than stock) Works great, no clearance problems, has the most filter media, and it's easier to put on and take off too. Part #14612 is the same filter in a stock length. Get them at Pep Boys for about a $5.00 to $6.00!
Sorry, I saw Long Beach and reccomended Pep Boys. Not sure who carries Purlator Filters in Georgia. Sombody must though.
[ This message was edited by: Stlakid on 2006-10-04 13:11 ]
10-09-2006, 05:54 PM
Location: El Dorado, AR smack dab in the middle of nowhere
I'm using a Walmart Supertech filter until I can make a trip to civilization and buy a better filter. Having said that, I think I read somewhere that W-M filters are made by Champion. At least they were a couple of years ago when Champion was one of the top filters in some internet comparison. Anyway, it's inexpensive, easy to find and it works. What more could you ask for in a pinch?
I will be strong and courageous, I will not be terrified, or discouraged; for the Lord my God is with me wherever I go. Joshua 1:9
10-10-2006, 01:10 AM
That SuperTech filter is the best filter for 2 bucks, no question. If I couldn't get the Purlator and the Mobil 1 or Bosch (both are the same filter) models were not available I would not hessitate to use that one. So the $2.00 filter is my third choice, but I wouldn't spend all that much effort if my first choice was not an option. I might just go from first to third!
10-24-2006, 01:40 PM
Supersport 600 Favourite Bike: 2009 Triumph Sprint ST
Does anyone know if these will fit on an 05 Daytona?
10-24-2006, 02:55 PM
Moderator
Site Supporter Formula Extreme Favourite Bike: 04 Daytona 955i
Posts: 830 Other Motorcycle: 07 Victory Kingpin
I just changed the oil in my 04, basically the same as the 05 and I used the Mobil 1 M1-110. It fit fine. It is a tad longer, but not that much to be concerned about. I have to say this is the easiest oil change I ever did. Didn't even have to take off the fairings or put up on a stand.
Live as if you were to die tomorrow. Learn as if you were to live forever. - Gandhi
10-26-2006, 09:36 AM
Powerbike Favourite Bike: 2006 Triumph 955i Daytona
Posts: 330 Other Motorcycle: 2002 BMW R1150RT Extra Motorcycle: 1998 Aprilia RS250GP1
You could consider the reusable Charlie Busa stainless steel filter from www.venividivroom.com.
The S1 model is the correct one for Triumphs.
Linz
11-08-2006, 12:09 AM
You better check out this link before you WASTE near $100.00 for a junk filter. I'll stick with what we KNOW works. Near the end of the page refers to the stainless filters and it all make perfect sense. Compared to a $5.00 Purlator these things let in WAY to much of the BIG particles for my taste!
Filter info
