Tire help - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda PowersportsNew BonnevilleMotorcycle.com Classifieds!SportbikeTrackGearOntario Tourism
Old 09-17-2006, 02:53 PM   #1 (permalink)
Warblade
i have a 98 955i and it needs a tire...i know the size is a 190 but my buddy has a couple of 180 i can get for free i was wondering if anyone has used a 180 and can i use a 180 or will it effect anything...thanks in advance
Old 09-17-2006, 04:58 PM   #2 (permalink)
ewolfkiel
180s will fit just fine, I would've gone with the 190 if I had the $$$$
Old 09-17-2006, 05:29 PM   #3 (permalink)
Moderator
Favourite Bike: 04 Daytona 955i
TechmanBD's Avatar
Other Motorcycle: 07 Victory Kingpin
Yes the 180/55 should work. That is what I put on mine. It handles better in corners withteh 180 compared to the 190
Live as if you were to die tomorrow. Learn as if you were to live forever. - Gandhi
TechmanBD is offline   Reply With Quote
Old 09-21-2006, 04:21 PM   #4 (permalink)
CanyonCarver
I agree; You'll find the 180 will significantly improve the handling. I went to a 180 many years ago and was very pleasantly surprised by how effortlessly the bike flicked into corners compared to the 190.
Go for it!
Old 09-23-2006, 10:50 AM   #5 (permalink)
Favourite Bike: My 02 955i
the955iman's Avatar
180 on mine and the handling is so much better than the 190.
Somehow I had this idea when I was growing up that if you wanted something bad enough, you would work hard until you got it. That was then. This is now. Now you vote for it. That's change you can believe in.
the955iman is offline   Reply With Quote
tire changes triumphtimes Daytona Deliberations 8 10-24-2007 06:12 AM
Tire wear vis a vis tire sizes KaHOnas Sprint Forum 10 04-15-2007 05:18 AM
Tire pressure and mixing tire brands RJScotti Hinckley Classic Triples 6 09-30-2006 03:56 AM
Need Tire SpRiTaL Triumph SuperSports 3 05-06-2006 10:52 AM
New tire vol245 Twins Talk 2 04-22-2006 11:48 AM
